Question about Iomega (33275) 500 GB USB Hard Drive
My 500 GB will not turn on properly. I've tried rebooting a couple times, but everytime a solid red light comes on. If i try restarting using the Power button the redlight begins flashing. Trying to conenct locally to backup files, but my PC (vista) won't recognize at all, even with crossover cable. Help
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Posted on Sep 13, 2010
  • Your harddrive is not recognize in any computer also if your usb cable and cross over cable is fine then there your harddrive needs repairing .
CRITICAL_PROCESS_DIED
replace the hard drive with a solid state hard drive as it is failing
while you have it partitioned , that is only 2 sections on the one disc and if the hard drive is failing , regardless of of the partitions , it will not read right
If you will , consider partitions as different tracks on an album and if the player is broken then none of the tracks will play properly
Jun 28, 2016 | Hard Computers & Internet
It will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
Have brought a new external hard drive for my laptop, i've plugged it in and the system sain it was installed successfully but its not showing in my computer have tryed restarting a few times, i've...
If you are using a usb hub disconnect it completely and try connecting your Western Digital directly to a usb port on your laptop. If that doesn't work try booting into safe mode and see if it shows up then. If it works in safe mode a recent update to your virus program or another program could be blocking it. Hope I was of some help , Thanks for using FixYa
May 11, 2011 | Western Digital My Book Essential Edition...
Everytime I try to print lables, it prints one or part of one and then stops and the red light comes on. I've tried restarting it, turning it on and off. What is the problem?
press the botton 2 times to run calibration, if not work, press button untill flash 7 times, if not work, chek the setings from driver (if use labels with gaps, use non-continues) (if use ribbon, use Termal Transfer) chech the settings (sensor ir on GAP/Web)
Nov 10, 2010 | Zebra TLP 2844-Z Thermal Label Printer
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
Its a usb drive. when i turn on the power. it
hi I am vortash it will show 0kbs in the management if it hasn't been installed as the system can't read it . I was wondering if the hard drive was installed with the lead in the wrong way as that is what it sounds like , ( I mean in the housing the ide plug may be up side down ) I have had a couple like this and the customer has made this very common mistake ,.. check this first then if you have a disk with the Fanton program on install it without it being connected so when you reboot after pluugging it in it finds it and loads the drivers itself ... I hope this solves your problem Regards Vortash
May 17, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
500 gB doesn't respond to anything!
Leave it unplugged for a minute or so and see if it boots up.
Check the Power supply if it still works.
Aug 21, 2008 | Western Digital 500GB My Book World...
Iomega (33275) 500 GB USB Hard Drive Logo
167 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
