Question about Lexmark T644 Laser Printer
Why does it print black pages? It prints a half
Why does it print black pages? It prints a half of a page then it is all black and the next page is all black.
    Sergeant:
  • 420 Answers
Maybe the inklevel is very very less
Posted on Sep 13, 2010
  • Official Brand Answer
  • 3,344 Answers
Try to print the menu settings page first. Follow the steps found in this link: http://bit.ly/caQvRm. If printing the menus settings page gives you the same result, you may need to clean the charge rollers or you may need to replace it. If printing the menu settings page looks normal, then it's a driver issue. Uninstallation then reinstallation of the printer software may help. For further assistance, don't hesitate to contact Lexmark technical support. Thanks.
  • 25 Answers
SOURCE: Lexmark E320 Printing big black smear
1. Make sure that you removed the entire paper jam and that nothing is caught in the fuser assembly (the part that gets hot so make sure it is cooled off first,also do not use anything to dig at anything that might be there try carefully using a tweezer or needle nose pliers to pull it out.
2.Remove the toner cartridge and with a dry cloth or a pencil eraser clean off the contacts on your left when facing the inside of printer and the roller on the bottom can be wiped off to remove excess toner.
3.With toner cart. still out use a dry cloth to wipe the laser print head area located directly above the roller on the bottom of the printer be careful as the metal edges are sharp.
4.If there is a build-up of toner at the entrance of the fuser try gently removing it with a flat blade screwdriver with care.
5.If this doesn't help it may be necessary to replace the toner cartridge itself.
Best Luck
Posted on Mar 11, 2008
  • 82 Answers
SOURCE: black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Posted on Apr 06, 2008
SOURCE: Only prints half the page
Have you been using any new software to create your documents? Go through the full dialog box of page setup info. You may have conflicting instructions, i.e. profile and landscape pages, margins, default printer settings, etc. Worth a try.
Posted on Nov 10, 2008
  • 68 Answers
SOURCE: my canon only prints half page?
Go to print setup try to cheeck the diffult.
Posted on May 20, 2009
  • 63 Answers
SOURCE: the printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Posted on Feb 10, 2010
Testimonial: "Thank you so much, I no longer have a problem. It seems such a simple solution now I know the answer! I thought it was something major."
Epson Aculaser C1750N printing black
When a color printer prints all black, it means the printer is putting either just black on the page, or all colors which appear black. The first step is to figure out if it's just black, or all colors. You can print a half page by opening the printer during a print. Then look at the page to see if there is any color in it. Try rubbing some of the toner across the page to reveal colors.
If the problem is black only, then try replacing the black cartridge. If the black toner doesn't fix it, then it may the the black laser or control module.
The all colors are on the page, then you probably have a bad control module.
Nov 25, 2014 | Epson Office Equipment & Supplies
Prints blank in black
your printer high voltage power supply board voltage is not correct .so please check the hups board
Apr 02, 2014 | Samsung SCX Office Equipment & Supplies
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
When I send my job to the printer. The printer will print but only on 1/2 of the page. it looks like the printer think i want two sheets on one page
Is the whole page you want printed on half the page is just half the data printed? If the whole page is printed on half the paper then the problem is software. If the page only prints the left side or the right side blank on the other side then the problem is most likely the fuser assembly. Can you take a picture of the page and email it to us, we will email you back with what needs to be done next.
Tech@ccl-la.com
Apr 30, 2010 | HP LaserJet 2300 Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Prints only on left side of page.
In printing web pages and email please try to check also the print setting before you print the page cause word document files and web pages are not the same in there printing setting. Web pages and emails has different setting so my recommendation is that when you print email and webpages next time then please check the printer settings then modify it the same settings as you wish or as your word document's output.
Thanks
Aug 18, 2009 | Epson STYLUS R230 InkJet Photo Printer
The printed pages with black is light and spotty.
Try to run the "Clean Print Heads" utility. Sometimes it is called something else, but whenever your print quality degrades, this is a good program to run. If that doesn't work, then I would suggest replacing the print cartridge. Sometimes they go bad if they have not been used for a long time. Hope this helps!
Mar 13, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Hp 2600n will not accept print jobs. Color cartridges show empty. black shows half full. Printing of a test page produces a great test page quality
I have two problems. Either it won't accept a print job or when it is printing it stops when it is going through the job intermittently. Like for an hour it won't continue then all of a sudden it prints one page then a half hour later another page etc. It is so frustrating.
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Hp6310 officejet all in one
here is solution..
Solution Step one: Make sure that the product prints correctly
  1. Print a self-test page from the product control panel, from Windows, or from the product software. (See the product user guide, available online, for instructions to print a self-test page.)
  2. Check to make sure that black and all colors (if using a color product) print on the self-test page.
    • If the self-test page does not print correctly, an issue might exist with the product hardware. See the product user guide, available online, for further troubleshooting steps.
    • If the self-test page prints correctly, continue with the next step.
Step two: Determine what portion of the page is set to print Many Web pages use frames. Frames divide the screen into multiple windows. Follow these steps to determine what portion of the page is set to print.
  1. Click the Internet Explorer icon on the desktop. The Internet Explorer window opens.
  2. On the File menu, click Print . The Print dialog box opens.
  3. Click the Options tab to view the print settings.
  4. Change the settings if required, and then click Print .
Step three: Change the Encoding setting in the Web browser
  2. On the Menu bar, click View .
  3. Click Encoding to view a list of encoding options.
  4. Check the Encoding settings.
    • If Auto Select has a check mark next to it, click to clear the check box.
    • If Western European Windows does not have a check mark next to it, select it.
Try printing again. If the issue continues, proceed to the next step. Step four: Check the page setup settings for the Web browser Web pages are designed to be viewed at a certain screen resolution. If the resolution of the screen is lower than the resolution of the Web page, the whole screen might not display or might not be printed.
  1. Make sure that Internet Explorer is open.
  2. On the File menu, click Page Setup . The Page Setup dialog box opens.
  3. Review the Margins information.
  4. Make sure that the margin settings are greater than or equal to the minimum printable region margins for the product. The margins vary slightly among HP All-in-One products. As a general rule, the settings should be at least the values shown in the following table. Side Margin Top Margin Bottom Margin 6.3 mm (0.25 inch) 6.3 mm (0.25 inch) 6.3 mm (0.25 inch)
  5. Make necessary changes to the margin settings.
  6. Click OK to save the changes.
Try printing again. If the issue continues, proceed to the next step. Step five: Print using Smart Web printing software HP Smart Web Printing is fast, free, downloadable software that enhances how Microsoft Internet Explorer and Mozilla Firefox print Web pages. Use HP Smart Web Printing for the following tasks:
  • Select text and graphics from any Web site
  • Save paper by combining portions of numerous Web pages
  • Preview and modify clips before printing
Thank you.......
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
Lexmark T644 Laser Printer Logo
1,764 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
