I have a lg lcd tv model rm-26lz30 with blue and red vertical lines on right side of screen. left side works ok
  • chriscokid64 Sep 17, 2010
    I have located the t-con board and i have carefully replace it only to have the same problem.I made sure the part was the correct part number . not sure what to do now.
    i appreciate your help. let me try and give a little more clarity on the tv. after long periods of no being turned on sometimes as little as 1 hour or more the picture will return normal, and will be ok for another 15 min. then the picture will begin to scramble only on the right side then i get lines and then lose the picture.it would seem to me their could be a temperature problem, with some component. the longer i turn the tv on the longer the recovery time to keep it off and the process begins all over again. just trying to give more information to make your diagnoses more accurate. would a bad lcd screen behave in this manor. i also notice when left over nights will work for longer periods when ambient temp is cooler.thanks
  • 11,800 Answers
That is caused by a failure of the t-con board - the board that actually commands the screen, connected to it directly by 2 wide ribbon connectors. You must replace it, a new one will cost you less than $90.
Posted on Sep 13, 2010
  • Azrael SRL Sep 17, 2010
    In that case sorry, but it's unfixable - the defect is in the LCD panel itself. Time for a new tv.
    The behavior you describe (finally with sufficient details) has absolutely nothing to do with the T-con board or the LCD panel - otherwise the colored lines would be there from the start, looking the same.
    What you describe is called image corruption and it's caused by a malfunctioning image processor or corrupt data coming from it to the t-con board. Since the problem appears as the tv is already functioning, it means that (as you guessed) it's heat related - the processor heats up and an fault in the transfer of the data to the buffer memory becomes apparent.
    The mainboard must be tested, you have a bad soldering on it. In the mean time you should try to increase the air flow to enhance the cooling: enlarge the air ports on the rear casing and even add a small fan.
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Panasonic TC-P50VT20 blank screen with vertical lines
http://electro-medical.blogspot.com/
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
LG MODEL#RM-26LZ30 PICTURE seems scrambled and vertical lines trough the middle of screen
DEPENDS ON WHICH BOARD THAT NEEDS REPLACING. Look on Shopjimmy.com they list boards and parts. If you know how to solder I would first resolder boards and check for Bad Capaciotrs they will be puffed up on Top.
Oct 08, 2012 | LG Televison & Video
LG - 32LD350 - 32" LCD TV - 720p is the type of tv
Hello
It has been permanantly damaged, and is not repairable. To get it work perfectly, you have to replace the screen. OK.
Aug 03, 2011 | LG 32LD350 32 in. LCD TV
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
