Question about Kenmore Dryers
We had 5 inches of water in the basement. ever since our dryer doesn't work. the light comes on, but that's it.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Motor got wet and is no good...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 14, 2010
Roper dryer red4400sq0
The heating elements and the motor would have gotten wet with that much water. You need to disassemble it and check both.
Jul 07, 2013 | Whirlpool Dryers
Basement flooded and got approx 12 inches of water in bottom of dryer let sit for a week to dry before trying when pushing start button will come on but wont continue running unless you hold button in ...
Sorry to say but you will need to replace the motor. After water gets in you can rarely save the motor no matter how long you let it dry.There is an internal over load inside the motor that is cutting out after 30 seconds and once it cools for 15 or 20 minutes then it resets .Hope you found this information helpful and thank you for using Fix ya.
Jun 24, 2011 | Whirlpool Dryers
Lg dryer basement flooded, water up about 8 inches on the dryer. in water about 8 hours, Dried it out turned it on panel worked drum turned but no heat then the drum stopped turning. just hums now? Is it...
there is a chance that the motor contacts have been corroded,depends on the age of the machine.and if there is a control board in the lower half of the dryer it could be as much as three hundred to fix it especially if you have a service tech come out and look at it if the unit is not under warranty.
Nov 21, 2010 | Dryers
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
I had water in my basement, now the dryer does nothing. fuses are good.
There is a controller board that is located on the bottom left of the dryer unit. This board is just over $100 as a replacement from FP. In most cases replacing this will fix the problem although I just replaced one on a gas dryer and it powered on but nothing else worked. The power light came on when plugged in but couldn't turn it off or change the setting from no heat dry. Could of been because no gas was attached but that is a question for another day.
This board will get wet and burn out when there is about 5" of water in the basement.
Jul 01, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Dryer won't run.
First, there is an excellent chance you have some kind of flood damage insurance.  It may pay for part of the repair.  You did not tell us what is not working but I'll guess it is the motor.  On many models, there is a switch on the motor which will not allow the elements to heat unless the motor is powered and running.
Dec 19, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
