Question about HP Photosmart E327 Digital Camera
I took my card from my HPe327 & put it in my HP109 printer, imported my images then put the card back in the camera. The display says 'card locked', how can I unlock it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Apr 26, 2011
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
I TOOK SOME PICTURES WITH MY NIKON COOLPIX S3000 & I EDITED THEM ON MY COMPUTER USING PAINTSHOP PRO. I PUT THEM BACK ON MY CAMERA BUT NOW I CANT VIEW ANY OF THEM I GET AN ERROR MESSAGE THAT SAYS...
Most cameras will not display images that were not taken on that camera (or at least a camera of the same brand). In addition, they will not display edited photographs. If you want to display edited photographs, you'll need to do it on the computer or a digital photo frame.
Jan 11, 2011 | Cameras
Transferred pics from computer to card and the camera will not display them - all are jpeg just like what the camera takes. These were from the camera but I wanted them back on the card also.
once out of the camera & deleted form the card, the camera will not display any of the images because it does not have that function. even jpeg images being the same format cannot be viewed.
Apr 21, 2010 | Kodak EasyShare One Digital Camera
Problem downloading image
One of the images did not finish writing to the card properly (usually in the last 4 or 5 images, or the last video)
Try selecting all but the last 10 images and chose import selected. This should work. Then delete those from the card.
This bit is important
Put the card back in the camera (if it's in a usb reader) if not, disconnect the camera and put it into playback mode. View the remaining 10 images/video.
Try re importing and it should work fine! I've had this problem since ilife '09 and this method always fixes it. It seems to happen when the cards get full. Try not to completely fill a memory card and you should not get the problem.
Apr 24, 2009 | Olympus FE-340 Digital Camera
My camera erased my pictures
These cameras have an internal store and also can use a card. So, when you add a card, it is writing to that store and only shows you the pictures stored there unless you change the device settings or remove the card.
If so, the images you have on the EasyShare One internal store may be originals
Another possibility is that you did a BragBook synch to EasyShare and you might be able to see these images in your 'Favorites' view. The 'Camera Favorites' or BragBook pictures are a smaller version of original images, to allow you to carry more pictures with you to share, but these pictures may be a lower resolution version of the images you took. They would be sufficient for printing 4x6 pictures, but not enlargements.
Change to Favorites mode to see if they show up that way.
DigiChick.
May 21, 2008 | Kodak EasyShare One Digital Camera
Locked
Look on the side of the card. There is a little switch. When you took it out of your camera you must have bumped it into the Locked postion. Just move it in the other direction and you should be set.
Good Luck.
Apr 08, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Images
This is no problem. Its work also in this condition bcz you import your image and in importing your all images in camera transfer to your pc, if you want to safe your images in your camera please use a card reader to copy your images in your pc. After that your all images also safe your camera.
I hope its very helpful for you
Oct 17, 2007 | Nikon COOLPIX S7 Digital Camera
Memory Card Problem
hey see page 105 of ur camera manual. if u dont have it see from canons site.
its says as follows:
sotry as i say. get one card reader and take back up of al the photos in your computer in which u have cameras EOS utiliys installed. now u have took back up of photos.
put tat memory card in your camera and do a low level format. this can be found from the options in menu in camera.if u dont get that ask me.
after formating it. connect the camera to computer and transfer the photos to the camera. your work is over i think. if not ask me. thank you
Oct 08, 2007 | Canon PowerShot A540 Digital Camera
Memory card problem
Download PC Inspector from www.convar,com run the stick through this program- if the images are there it will find them But of course no images may have been recorded Sony Tech Help Team will tell you more about the meaning of 'Access'
Jun 23, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
HP Photosmart E327 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
