Question about GE Refrigerators
I have a GE side by side that came with the house we just bought. Model No. GSS22Jeta CC The previous owners did not leave a manual. I want to know about the water and ice cube dispenser. Is there a filter? Do I need to change it, etc.
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
We have a GE Profile cooktop in the house we bought. I found the manual from previous owners of house and it is a JP350. It has white knobs (4 large and one smaller one). I would really like to have...
Bonjour, j'ai un four GE Profile électrique acheté en 2006 et lorsque je veux me servir du fourneau, tous les boutons digitaux sur lesquels j'appuie donne comme résultat "LOC On". La plaque fonctionne toujours bien c'est seulement pour la programmation du four que j'ai un problème. Est-ce qu'il se peut que j'ai appuyé par mégarde sur quelque chose qui verrouille les commandes car jusqu'à dimanche dernier il fonctionnait bien? Comment régler ce problème? Merci à l'avance
Nov 05, 2010 | GE Ovens
I bought a house that does not have any user manuals for the appliances. Do you know where I can get a Hotpoint Microwave, Model # RVM120G001 manual?
You can download GE owner's manuals and installation instructions here.
Jul 07, 2010 | Hotpoint Microwave Ovens
My oven display panel is 'dinging' me with this message: F2 The previous owners of my house didn't leave the manual. Model # is KEDT105VBL0 Serial # is F93105(7 or 1)44
Hello- The code described- F2 - indicates a fault in one of the switches on the control. This model has the switches on the board with the computer, and must be replaced as a unit. The control is pretty easy to install, but costs over 250$. Wish I had some good news for you. -Bet the previous owners didn't.  Let me know if this info explains situation. Only solution is to replace the control.  Thanks- Ed
Mar 19, 2010 | KitchenAid Kitchen Ranges
Water softener seems to be draining all the time
http://www.puritecwatersofteners.com/documentation/Hydrotech_5600MI_manual.pdf
I'm pretty sure this is the manual for your unit. It might not be exactly like the one you have but at least could give you info for it. This is something you might have to contact the manufacture for. Hope this helps!!
Mar 31, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Bought a GE Spacemaker microwave when it is on
First, check your owner's manual. It should address interference issues.
You can download GE owner's manuals and installation instructions here if needed.
Also check with Direct TV customer service to see what they recommend.
Microwaves manufactured after a specific date are required by the FCC to have a noise filter built in.
You can contact GE customer service to see if yours has one.
GE Customer Service is here.
If not, you may be stuck unless the dealer will let you exchange it for a newer model.
Mar 01, 2009 | Westpoint TV-201 Microwave Oven
Disarming / Access Code/ Resetting
Ask seller or previous owner the code, or read in the manual how to reset the system to factory defaults
On the previous version (Simon3) it was press cancel + clock set + Minutes+ at the same time and the power up from battery
Jan 05, 2009 | GE Security Simon 3 Wireless Home Security...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
