Question about Porter Cable 362 12 Amp 4 Inch By 24 Inch Belt Sander With Cloth Dust Bag
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
  • Porter Cable Master
  • 885 Answers
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Posted on Sep 13, 2010
  • 1,926 Answers
Most caused by . . . .
Often, a fracture of a drive belt in case of a worn-out engine house by melting damage of poor ball bearings.
When the driving armature becomes to hot by bad dirth ballbearings the armature bearing and the bearing of the capstan coming a little or more closer to each other the bearings stand towards each other by melt-damage, and therefore, the drive belt does not tight enough anymore to allow tearing through which pass the tips of the drive teeth.
Posted on Nov 15, 2016
We have an old Craftsman belt sander (bought in the 70's), Model 315.117130. It's a well-made, durable sander and we'd hate to give it up for the cheap junk that's made to break in a few years. Problem...
many of those the belt had to be put on in a specific direction . and if put on backward they failed rapidly something to do with the inner seam if memory is correct
Dec 17, 2017 | Tools & Hardware - Others
TOLEDO TBS-800 BELT
Where would I locate wheel rubber for sander Toledo tbs 800
Sep 15, 2012 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
I need a new belt for my porter cable 4X24 inch belt sander - model 362 - type 6 whisper series
I have had the hardest time trying to find a belt for mine.
I've made do with a 3 x 24 without any turmoil
I take it you are having similar problems
Mike
Aug 21, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 362 belt sander - the paper slips off
there might be a buildup of sawdust in the tensioning mechanism or the yoke might be bent. I would look at excess buildup in the mechanism first. there are 3 screws on the outside of the tool so you can remove the assembly as a whole. try and clean as thoroughly as possible. the mechanism should move freely and "snap" when lever released.
Jul 18, 2010 | Porter Cable Tools & Hardware - Others
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
My porter cable 362 belt sander will not adjust enough to center the belt. When the thumb adj. screw is completely free (lose), it rides about halfway across the roller and stays. I can't bring it back...
The slide arm mechanisms and tension arm, springs, etc. need a little light machine oil, 3-in-1, to make them slide easly, a few dropes will do the trick, do not over oil. Move the adjustment knob just hair at a time or it will over adjust, hope this helps you.
Mar 16, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 362 12 Amp 4 Inch By 24 Inch Belt Sander With Cloth Dust Bag Logo
1,147 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
