Question about NEC Versa Gold Submersible Pump
I have a versa gold G210AG20 I need a new impeller where can I get replacement parts for this pump?
Running pump stopped
I assume that the plug in is working properly. Always check power supply first. Is there a GFCI circuit that it is plugged into. Then check the pump to make certain it us turning. How long had it been on before unplugging it. It could be worn out. Sometimes it takes a jolt to start the motor again. How big is the motor. Possible bad capacitor. Could be a solid state motor, then it's bad. Is it a magnetic motor, that could be turning the wrong way.
May 16, 2014 | NEC Versa Gold Submersible Pump
Impeller
by Osko Pool n Spa If your Swimming Pool or Spa Pump Motor is humming and/or has very little or no water flow, please follow the following directions.
1) Remove the pump motor from the system.
2) Disassemble the front half of the Pump Pot Housing from the back half.
3) Check for any foreign obstructions which would jam the Impeller and remove it
4) Next, inspect the Pump Motor Impeller itself. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged and requires replacement.
5) Next, remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged and need replacement.
If everything seems to be in good working order, then you need a new pump... not just replacement parts.
May 26, 2013 | Hayward Pool & Spa
How to replace filter housing on Hayward Power Flo Matrix pump.
remove bolts around pump housing then remove parts to get to impeller impeller has reverse thread impeller comes off regular thread then reverse less hassle replace whole pump
Jul 16, 2012 | Hayward 1hp Power Flo Matrix Above Ground...
Our Whirlpool Gold dishwasher does not drain. What
Hello there:
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
MotorIf the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer.
Mar 20, 2010 | Dishwashers
I need an impeller housing (part no. CX1777) for a Beckett Versa Gold G325AG20 pump.
The web site for "Otimus home" will get you in touch with more parts than most sites. This site is for pool parts they also have a site for spa and smaller pond equiptment.
Aug 20, 2009 | Garden
I have versa gold submersible pump, it works intermittently. There is enough water in the pond and it is submerged
Intermittent running usually points to intake or impeller obstruction. Remove the impeller screen and cover, inspect the impeller, the screen the discharge exit point for debris. Unlike other brands the impeller is not replaceable if worn or damaged.
Jan 25, 2009 | NEC Versa Gold Submersible Pump
We have taken apart the bottom of the dishwasher to be sure no food was clogging the exit. It is clear but the water still willnot drain
HI In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Oct 13, 2008 | Dishwashers
NEC Versa Gold Submersible Pump Logo
324 people viewed this question
Top NEC Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a NEC Garden Expert? Answer questions, earn points and help others
