Question about General Electric DHDSR46EGWW Dryer
Hello, GE dryer Model #DHDSR46EGWW- All control knobs have gone haywire on top control panel have gone haywire. Start button inop, Settings for clothes type is questionable, buzzer goes on when not activated, can only dry fairly well at one setting-timer inop. What is this?
5 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: the white hard plastic pin the the timer knob
Timer switches are normally not repairable.
You will have to replace the timer switch.
When you do, make sure you get the right timer switch, and remove and connect one wire at at time. This will save you problems later if you get the wiring confused.
You can go to this website for parts or your local part supplier or search other suppliers on the web:
http://www.partselect.com/
Good luck,
I hope this helps
Posted on Oct 05, 2009
  • 401 Answers
SOURCE: starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Posted on Jan 04, 2010
TheMobilian
  • 8220 Answers
SOURCE: replace broken start knob on ge dryer model
I have one up at the hunting camp. I remove the switch and took a dremmel tool and cut a slot in it. I Use a flat blade screwdriver to start the motor. It is just 2 wires going to that momentary switch. It is an old dryer and I didn't want to spend the money on a new one. Anyway you remove the back of the control panel. (Unplug the dryer) Lift the locking tab up and twist the switch a hair. It drops right out.a817090.jpgSee the tab sticking out. Just lift it up a little bit and give the switch a twist.
Posted on Jul 25, 2010
Joe Onley
  • 363 Answers
SOURCE: I need a replacement start
I found the knob page... click HERE
Posted on Sep 01, 2011
How do I remove the lid off of a GE dryer
Try: http://www.appliancerepair.net/clothes-dryer-repair-4.html
They can probably help, especially if you have a reason to take the top off and it is not performing properly.
Apr 01, 2015 | GE Dryers
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Oct 21, 2008 | GE DCVH515EFWW Electric Dryer
Searching for Model Number for a
post a picture of the dryer with the door open
Dec 27, 2012 | Dryers
GFDN240ELOWW
My husband just fix my GE Dryer GFDN240WW "Start Button broke" issue. Here is what he did; He removed the control knob to access the phillp screw. Unscrewed screw and lift up on control to remove panel and unhook power supply. Then set control panel on face. Unscrewed 5 larger screws to removed black plastic panel w/ mother board attached. Set board aside and located power button which was broke off. Compare button to all other buttons on panel to see how they are attached to panel. My husband used Plumbers Goop from Lowes store to attached power button like the others. Then he reassembled the dryer and presto! It works!
Jun 09, 2012 | GE Dryers
Remove front panel ge spacemaker dryer
Here's the trick: The Spacemaker dryer is the same as many other GE dryers but is upside down!
1. Unplug the dryer.
2. Flip the dryer upside down so the white panel is now on top and the unfinished steel panel is on the bottom.
3. Remove the 2 screws that connect the bottom, white panel from the back and lift up to remove.
4. Pull off the Settings and Fabric knobs on the front of the dryer. Take off the front control panel (remove the 2 screws).
5. Remove the 2 screws that attach the front panel (located behind the control panel you just removed). Hold the dryer drum by the top edge and pull the front panel away (note that the panel will be hooked to the rest of the dryer at the bottom corners). DO NOT PULL AWAY ENTIRELY!
6. Disconnect the wiring that is attached to the front panel (these come apart easily by hand but you might want to mark the wiring so you know where to connect it when reassembling).
Apr 05, 2012 | GE Spacemaker DSKS433EB Electric Dryer
GE dryer model DCA3BC8776 'Start' knob has come
you should be able to replace the knob from the front of the panel without removing the control panelit has a "D" shaft on the knob and shaft also has a "D" configuration too? right?
Aug 18, 2011 | Major Ge Dryer Timer Knob We1x1263
Replace broken start knob on ge dryer model #DHDSR46EG1WW . i was just using the little post, but my son broke that off and now it doesn't work at all.
Jul 25, 2010 | General Electric DHDSR46EGWW Dryer
Dryer does not automatically stop, takes too long also.
you need a timer you can probably take the old timer in to your local appliance part store and get a new one
Apr 20, 2009 | General Electric DHDSR46EGWW Dryer
Squeaking in GE ds4600 Dryer
Every unit is different. Some units you have to remove the electronics and the top of the unit first before removing the back panel. Try laying the unit on it's back and see if you can access the unit from the bottom.
Apr 18, 2009 | General Electric DHDSR46EGWW Dryer
General Electric DHDSR46EGWW Dryer Logo
115 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
