Question about Mitsubishi Televison & Video
I have a 50 in mitsubishi television when i plug in an hit power button i hear a click sound and it wont power up
  • Mitsubishi Master
  • 11,800 Answers
That click is the power source's relay engaging - if you don't see any change is because the power source has had a major failure. Unplug the tv from the wall to limit the damage and call a repairman, there's nothing more you can do.
Posted on Sep 13, 2010
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
Multiple issue,power light flashes
Sounds like first loose connection on circuit board. I would first look around the relay this is what clicks. Then also the low voltage transformers. These problems are always concerns when set is moved or bumped hard. Try this first. Or it could be a heated issue.
Nov 26, 2007 | Philips 50P8341 50" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Jun 16, 2008 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi tv
Could be a power supply problem - sounds like the feeder cap was failing slowly until the heat stress on the regulator finally gave out.. You'll want to check the following: Strm6515A (That's the regulator, R9a23 1.2 ohm, C9a15 220uf/35v , R9a0 1k all in that feed circuit for the regulator.
Bill
Jan 29, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Televison & Video Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
