Question about HP Office Equipment & Supplies
My printer is printing double. It is a 2575 Photosmart All in One. What can I do about it ?
    President:
  • 1,194 Answers
This problem usually occurs when there's a paper jam and somebody just dragged the paper to clear the jam, May be printer Print Head got mis-aligned, You need re-align the print cartridge:-
1) Go to HP Solution Center, Click Settings , point to Print Settings , and then click Printer Toolbox . The Printer Toolbox appears. Click DEVICE TAB the click Align the Print Cartridges. Make sure you put paper in the tray before performing Aling the print cartridges steps. An alignment sheet prints.
2) Place the alignment sheet with the print side down on the right front corner of the scanner glass.
3) On the product control panel, press START SCAN/REPRINTS. The product aligns the cartridges.
& clean printer cartridge & ink nozzle also
I hope this will solve your problem
Thanks..!!
Posted on Sep 13, 2010
  • 24 Answers
SOURCE: HP Photosmart 2575 xi
you need to mention is the half print occurring during a print out/scan /photocopy? Follow these steps to try and resolve the issue: Step one: Reset the printer Unplug the all-in-one USB cable from the computer. Verify the computer and the all-in-one have a three-prong power cord that connects to the power outlet. Unplug the all-in-one power cord from any power strips or surge protectors, and plug it directly into a wall outlet. Make a copy or scan, and see if the issue is resolved. If not, proceed to the next step. NOTE: If the scanner bulb is not lit during a copy or scan, the product needs service. Step two: Clean the glass and scanner backing Turn off the all-in-one. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the all-in-one. Raise the lid. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry. Step three: Try a blank copy Plug the power cord back into the wall outlet. Plug the power cord into the all-in-one. Turn the power on. Close the lid; do not place any paper on the glass. Load paper in the paper tray. Do either of the following: Press Start Copy Black to start a black-and-white copy job. Press Start Copy Color to start a color copy job. If the output is a full/half-black page, or has vertical black lines, the product needs service. Step four: Service the product If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Posted on Sep 25, 2007
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
oldnovii
  • 667 Answers
SOURCE: Photosmart 2575 printer is offline - won't print
Hey jonboy - You do not want to delete it. It is automatically installed with Vista. In simple terms, you know when you go to print something and it asks you questions like print all pages, print page 1, etc? Well XPS basically is there for so when you go to print, you have the option of printing to a file instead of paper. You've always had that option ( whether or not you knew it) but this is just a new way of doing it and that's why it's listed under printers. It's sort of like a virtual printer. I'll say no more about that and just hope you understood what I said. As far as the other printer, it's already selected as default, go back in where you found the printer status, right click on your Photosmart and click on use online. That should do the trick.
I hope you understood this stuff. If this solves your problem PLEASE rate this as fixed. If you still have a problem, DON'T RATE it yet just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 09, 2008
leroyal
  • 2120 Answers
SOURCE: ''HP 2575 printer prob
Clean the scanner glass
Posted on Feb 21, 2009
Don't have the cd to install my printer onto my new computer. HP 2575
go to hp site and go to support tab/ drivers download/printers/2575 and download the install file or birn it to a cd.
Oct 10, 2010 | HP Photosmart 2575 All-In-One Printer,...
How to get free download for a hp 2575 photosmart manual frank
Hello there
Here is some information below that will help you get the manual ok?
I hope that this is very helpful
best regards michael
HP Photosmart 2575 Manuals, Support and Troubleshooting ... Free download of HP Photosmart 2575 User Manual. Troubleshooting help from
experts and users. Ask our large community for support. http://www.retrevo.com/support/HP-2575-Multifunction-Printer... - 107k - Similar pages HP Photosmart 2575 review - Multifunction Printers Quick links to useful Expert Reviews for HP Photosmart 2575 describing pros and
cons. User sentiment in Forums. Download to User Guide and Manual. http://www.retrevo.com/s/HP-2575-Multifunction-Printers-revi... - 85k - Similar pages
Nov 16, 2009 | HP Photosmart 2575 All-In-One InkJet...
The color ink cartridge '97' is being rejected by
hi,
this problem may be due to the senser in socket where you are insert the cartridge. so pls clean the socket with cotton using cleanin g liquid eg petrol , spirit or even nail polish remover
Aug 17, 2009 | HP Photosmart 2575 All-In-One InkJet...
Unable to print or scan with HP Photosmart 2575 to new Vista
That means that the printer software installation is corrupted.
You need to reinstall the drivers for this printer.
If you have original printer disk, use the disk to reinstall the printer.
If you have misplaced the disk, then you can download driver from link below:
HP Photosmart 2575 All-in-One Printer
Run installer file after download has finished.
Start driver installation with printer USNB unplugged, the printer setup wizard will tell you when to connect the printer to computer.
Set the printer as default when asked.
Feb 17, 2009 | HP PSC 2410 All-In-One InkJet Printer
Photosmart 2575 instant share
I installed the free software from HP's website. Simple as that.
May 21, 2008 | HP Photosmart 2575 All-In-One InkJet...
PhotosmaRT 2575
You need to adjust the printer using the ajustment utility on the printer itself.
Apr 25, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP PhotoSmart 2575
hmmm..sounds like a new set of drivers might be just the thing.
get em here
Mar 05, 2008 | HP Photosmart 2575 All-In-One InkJet...
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
did a search on hp website and found over 100 hits
go here to find out what your error means
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Dec 23, 2007 | HP Photosmart 2575 All-In-One InkJet...
Seeker5211
Seeker5211
