Question about McCulloch Garden
I have a McCulloch Trim Mac SL+ which will not idle. No matter how I try and adjust the idle screw it cuts out.
    Brigadier General:
  • 4,088 Answers
Which idle screw are you adjusting, the idle jet (L) or the idle speed screw which sets the throttle stop position. Adjust the idle speed screw while watching the throttle stop position so that it is pushed away somewhat. Adjust the L jet needle CW to stop (lightly), then back out 1-1/2 turns CCW. This should allow the engine to idle after warm up. Turn the needle CW while running for better idle, yet it should allow the engine to 'follow the throttle'. If this doesn't work as described, then check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. You may need to remove the carburetor and clean it inside and out with spray carburetor cleaner. For further insight, go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This material applies in general to other brands of carburetor as well. Hope this helps!
Posted on Sep 13, 2010
MAC 110 Starts but won't stay running?
Check fuel line integrity, could be a split pipe. Could also be a tick over problem. If it revs fine then try adjusting the idle screw.
Apr 27, 2016 | McCulloch Mac 110, 120, 130, 140, 160, Eb...
What is the initial carburettor adjustment for a mac 120 MCCulloch chainsaw?
Hi williamsc32...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Sep 28, 2012 | McCulloch Mac 110, 120, 130, 140, 160, Eb...
Mcculloch power mac 310 chainsaw Carb adjustments
The idle adjustment screw will probably have a spring on that screw and will push directly on the throttle linkage. You just adjust this screw until the engine idles like you want it to. I believe on saws, they have to idle to where the clutch will not engauge when the engine is at idle. As for the mixture screws the low speed screw (L) you adjust when the engine is at idle, the high speed screw (H) you adjust while the engine is running with a good bit of throttle. Once you get the idle speed where you like it, then all you have to worry about is the mixture screws. When adjusting the screws, just listen to the engine, to much one way and the engine will run rough and sputter, to much the other way the engine will run rough and maybe start hunting (reving up and down). One thing to check on these small 2-strokes is that the air filter and the muffler are not clogged cause if they are, then you would be having to adjust the carburetor to make up for the air restrictions that these two problems can cause which would mean that the carburetor isn't actually adjusted perfectly.
Oct 23, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Have a mac 3516 35cc the carberator is way out of adjustment where do i set idle and gas adjustment screws at
I have always found that a good place to start was to close both completly shut then open 1 1/2 turns. On idle adjust to where it will idle good and chain is not moving. At run speed adjust slowly to where it runs the smoothest at max R.P.M.s. Hope this helps.Thank you.
Dec 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to adjust idle on McCulloch Mac 2214av chainsaw
Look for 3 adjustment screws on the carb. should be three total. 1 screw is for idle adjustment. the other 2 should be close to each other, one is low speed fuel/air mix and the other is high fuel/air mix. Adjust the low fuel/air mix screw until it will idle un-added with the throttle then adjust the idle on the throttle to get a good idle speed. Next adjust the High fuel/air mix until it gets the RPM's you want it to have. It should go from idle to high speed with out hesitation or cough. . Start with 1 1/2 turn out from all the way in. Be sure the filter is clean, You can use starting fluid or old school lighter fluid to aid starting if has been sitting for some time.
Oct 10, 2010 | Garden
How to adjust carby settings after rebuilding. McCulloch Eager Be
Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that should allow the engine to start and run. Start the engine and allow to warm up, then pull throttle full on. Adjust H needle CW until the engine starts to speed up, but continues to 4-stroke. Proper setting is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Aug 01, 2010 | McCulloch Garden
Carburetor settings for mac 10-10
Check the fuel filter, air filter and muffler for plugging. Check the condition of the fuel lines. Make sure the carburetor fasteners are tight. Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting which should allow the engine to start and run. Do so, and allow the engine to warm up. Pull the throttle full on and adjust H jet CW until the engine speeds up somewhat, but still 4-stroking. Correct adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and allow to idle--adjust L jet CW so that the engine runs fairly well, yet allows the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jul 02, 2010 | McCulloch Garden
Starts, idles and runs but quits after a few seconds of cutting
Check the air cleaner and muffler for plugging. One screw adjusts the idle stop (idle speed) position and the H and L jet screws set fuel mixture for high speed and idle speed mixture respectively. Turn both jet screws CW to stops (lightly) then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine starts to speed up, but 4-strokes. Correct adjustment is when the engine 4--strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 17, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
The second hand McCulloch 120 chainsaw I purchased
I think the pre-adjust settings are to turn jets in all the way and back out 1.5 turns each. then:
You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 08, 2009 | Standard Oregon Chainsaw Chain For...
Garden Logo
601 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
