Question about Motorola Mobility RAZR V3
Cmmera Problem I did Master Clear and Update and did not help any. The result its friezes up and I must take the battery out to get new start the phone
    Brigadier General:
  • 7,752 Answers
Have the mobile firmware reflash on the phone
Posted on Jun 02, 2008
My GY-145 Good year has missing reciption and was friezed. It seems need to be update.
There are no updates available at the present time. You may try a hard reset which involves finding a small pinhole on either the back or bottom (may have small writing that says reset near it) and pressing the button down for ten seconds with the tip of a paperclip. Hope this helps you fix your device.
Mar 10, 2011 | Goodyear GY-145 Car GPS Receiver
My imate jama 101 is freeze at startup its not working
TRY HARD RESET
1) Start->Settings->System tab->Master Clear->1234->ok
2)Press soft-reset for 15sec.
3)Remove the battery, Simultaneously hold volume(-) button and red hangup button, while still holding those keys, insert the battery and wait for the led to go out, release keys and device will hard reset
the 3rd option really worked for me
May 24, 2010 | i-mate Jama 101 Smartphone
Razor shuts off by itself
your probly right.....its either corupt software of a battery issue....try the obvious first (remove and reinsert the battery if you havent already)....if that fails, try the master reset.
MENU > SETTINGS > INITIAL SETUP > MASTER RESET
**default code is 000000 (6 zeros)**
if THAT doesnt work, try a different battery. you can pick them up cheap if you dont have one lying around from www.amazon.com or www.shopmotorola.com
if thats not an option, try a master clear. if you dont want to buy anything, i would try this first. the master reset just sets everthing back to manufacturers default.....the clear DOES. you will LOOSE EVERYTHING INSTALLED ON THE PHONE MEMORY.
to do this, go to MENU > SETTINGS > INITIAL SETUP > MASTER CLEAR
**again, default code is 000000 (6 zeros)**
good luck :)
Jan 26, 2009 | Motorola Mobility RAZR V3
G'day, I have the Edge205 and cannot get to operate, fully charged battery, and will not recognise connection to computer, can you advise please as to how I can get started, thanks Ken
To fix this problem you will need to download the latest version of Training Centre from the Garmin website and also update your units software.
Update Training Centre:
  1. Close Training Centre if its open on your PC
  2. Visit http://www.garmin.com/support/download_details.jsp?id=835
  3. Click Download
  4. Click Run when prompted
  5. Follow the onscreen instructions to update Training Centre on your PC
Update the software on the device:
  1. Visit: http://www.garmin.com/products/webupdater
  2. Follow the onscreen instructions to Download WebUpdater
  3. Click Run when prompted
  4. Follow the onscreen instructions to install WebUpdater
  5. WebUpdater will run automatically once installation is complete
  6. Follow the onscreen instructions to update your Edge
If the above steps do not correct the issue, then you can carry out a master reset on the unit as a last resort:
Note: The master reset will clear all user data including training history from the unit
  1. Turn off the Edge
  2. Hold down Mode + Power
  3. Select Yes when the unit asks if you want to erase all user data
  4. After resetting your Edge, leave it with a clear view of the sky for about 30 minutes without moving it to acquire a GPS fix
Oct 13, 2008 | Garmin GPS
Rainbow shampooer and frieze carpet
yes, it can be used without harm, but try a test area to be sure the dye is not cheap
Aug 21, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Olympus E-300 Evolt - LCD Screen doesn't come & SSWF light stays on
My camera is working again, but the problem is not completely solved. What I did was to put on the old lens, take out the battery then turn on the camera and finally put on the battery again. And now it works. But the problem with the new lens (Zuiko digital 40-150) continues.
Jun 30, 2008 | Olympus EVOLT E-300 Digital Camera
Could you please pass reformatting info my way?
try a master reset of the phone
MENU
SETTINGS
INITIAL SETUP
MASTER CLEAR - 000000
MASTER RESET - 000000 - security default code
Jun 12, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Apr 06, 2008 | Garmin nuvi 350 GPS Receiver
Hard Reset
Hello DoctorJ16,
If you mean hard reset as in reflashing the unit with software, it shouldn't make too much of a difference. Are you experiencing a problem with the unit or you just want to set everything back to default?
You can get similar results by performing the master clear and master reset option.
Go to the Menu and click on Settings
From there you'll want to scroll down to "Initial Setup"
Scroll down to the bottom and you will see both Master Clear and Master Reset.
I suggest you do the Master Clear first, the code should be six "0", entered "000000".
After which you can perform the Master Reset, same code.
Hope this helps,
cHiPz.
Apr 01, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Help! thought battery was dead but...
try a master reset and clear all data on the phone......if that does not work have the phone's firmware reflash by taking it to a professional mobile store and getting it done there.
that should fixed you issues with the phone :)
Jan 09, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
