Question about HP OfficeJet 4215 All-In-One InkJet Printer
How do i have all output print in black & white
  • 506 Answers
You can print your output as draft and it will all come out black & white or select all the document and change the font colour to black and send the your printer.
Posted on Sep 13, 2010
5 Suggested Answers
  • 16 Answers
SOURCE: black & white setting is printing red
lh kuwe nek kowe ra blajar!kon blajar angel nemen !kuwinek domongi wong tuwa ra manut ya ngono kuwi..wis muleh bae nang ndeso
Posted on Aug 11, 2009
komguy
  • 2306 Answers
SOURCE: Will not print black text.
You need a new printhead, QY6-0061-000, around $60.00
Posted on Sep 25, 2009
  • 111 Answers
SOURCE: Canon Pixma 3600 I want black
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Posted on Jun 06, 2011
caroldon
  • 17129 Answers
SOURCE: will not print black & white. color only
You need to reset the B&W and the coIour cartridges and then reset the printer. Often the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Check the leads from the mother board and also the contacts of the ink cartridge , if jammed or tight remove and manually free the drive before it is set back.
Thank you for using FIxya
Posted on Sep 05, 2011
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
Sep 30, 2013 | Office Equipment & Supplies
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
example:
Jun 06, 2011 | Canon Office Equipment & Supplies
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
Trying to print in black & white only
THis option is in the printer driver.
under Printing Preferences
Graphics
Output Color
Change this to BLACK
Jul 01, 2009 | Dell 3110cn Laser Printer
Kodak ESP 5 runs out of ink after about 40 pages of standard text black & white documents. Also the color ink level is dropping, but no color is being used (the printer is set for black & white...
As far as the quantity of black & white - to get more out of it - go to start menu.. Click on on settings,, then printers,, Right click on the ESP 5,, click on printing preferences,, then clcik on draft,, then click on (at the top) advanced,, click on black & white.. Then click on apply then ok..
Now - every time you print it will be in this mode.. If you want to print in color - you will have to choose that each time..
For you black & white docs - this will print faster & use allot less ink..
As far as your color issue & puddling - It could be the printer head.. If it is new enough - call Kodak & maybe get a replacement.. If to old - maybe keep the color cartrige out and caped with the plastic caps until you need to print color.. Snap it in & out as needed..
I hope this helped..
Jun 11, 2009 | Kodak ESP 5 Printer
Need a wiring diagram for a clarion db185mp
SPEAKERS:
Green = Left Rear +
POWER/ACCESSORY:
Black = Ground
Brown = Phone Mute
RCA Cables:
Gray = Front Output
Black = Rear Output
Dec 27, 2008 | Clarion DB185MP Car CD/ MP3 Player
HP OfficeJet 4215 All-In-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
