Question about Frigidaire Washing Machines
My Frigidaire Stacking Washer/Dryer Model FLSE60RGS2 will not spin or rinse and is full of dirty water and clothing. HOW do I go about removing the housing to check for stuck clothing or a bad belt?
5 Suggested Answers
SOURCE: Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Posted on Dec 26, 2007
SOURCE: Frigidaire crown series dryer
leaving rust stains on clothing - ruining the clothes. Thats my problem. I don't have solution yet, let me know please, Thanks
osopower1@yahoo.com
Posted on Jan 24, 2008
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
  • 396 Answers
SOURCE: frigidaire stacking washer will not spin in rinse
If the unit works when it is on the floor I would suspect three problems.
First make sure the unit is level using a bubble level checking left to right and front to back.
Second make sure the unit is securely on the dryer so when it spins it will not become unbalanced. You should see the washer spin slowly increase in speed and starting to violently shake then slow down again never achieving top speed if this is a problem.
The last possibility is to move the drain hose so it has a loop in it. Use a string, rope or hook it over something to hold the hose up so it will be at the height of the middle of the drum or higher and goes back down into the drain. Washers use a combination of a pump and capillary action to drain. This will also stop water seeping out of the hose when the drum is full allowing it to fill to full capacity.
Posted on Jan 14, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
I have a gleh1642fs4 model that drum will not spin?
I have a GLEH16242 Frigidaire/Electrolux stacking washer/dryer. The main bearing went out on the washer. I did the expensive fix of replacing the outer drum/bearing assembly in hope of nothing going wrong. Everything went together well, but now it won't go into high speed spin. It does if I have no clothes in it, but as soon as I introduce clothes it only does the 'medium spin' but never advances to the high. I've changed shocks, confirmed the door switch is working properly and double checked level. Even placed it on a big thick sheet of plywood in hops of stabilizing it more. It does have a wobble to it when it starts spinning, but when it kicks into medium spin, is smooths out.
Oct 11, 2013 | Frigidaire GLEH1642DS Front Load Stacked...
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
Frigidaire stacking washer will not spin in rinse or spin cycle
Jan 14, 2010 | Frigidaire GLTR1670A Front Load Washer
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
Stacking Frigidaire Washer Dryers
no you do not need to put them on rollers. yes it would make it easier to service them but rollers would not be stable enough to keep the washr from shaking in spin cycle.
Jan 23, 2009 | Frigidaire Washing Machines
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
