Question about Vacuums
New wheels for my Samsonite case? one wheel has completely seized
  • 17,130 Answers
You might get replacement ones but maynot be the same type.
So it is better to get details from their site noted below:
give your request in the contacts site :
www.samsonite.com
Posted on Sep 13, 2010
Hoover SpinScrub 50 wheels won't spin
The bearings in the turbine are prone to seizing because of moisture. Take it to your local vacuum repair shop and have them repair it. At my shop we re-grease the bearings and it's better than new. If there is too much damage the turbine will need to be replaced
Sep 07, 2017 | Hoover Vacuums
It's locked and everything imp like my clothes atm etc is inside I am using this bag for first time but it's not opening up
Dial the three wheels to 0-0-0, which is the default combination setting for American Tourister and Samsonite luggage.
Try this setting
Feb 24, 2016 | Vacuums
Mu Singer Futura II model 920 hand wheel seized up-it will not turn. any ideas?
Turning towards you? that is correct. It could be something else that is wrong, like needle hitting the plate, thread jammed etc...and you think it is the handwheel when the handwheel is just not turning reflecting something else. What I always do is take everything out and off...bobbin, bobbin case, feed dog plate, etc...and even remove the needle. Take your brush and get every last bit of lint out of the areas it might be. Something is hung up. When you put your needle back in, make sure it is up all the way, and use a new one. Maybe this will help, but if not, call Singer or take it somewhere as it might be a simple fix.
Feb 13, 2015 | SewShop.com Singer Model 920 Futura II...
When we changed the belt the new belt broke right away and the brush roller wouldn't spin. My husband cleaned off the roller and got it moving slowly again, but when we went to re-attach everythin
the thing you call wheels are actually called roller bearings that fit at both ends of the brush-roll there probably seized up you can get a new brush-roll with bearings from the link below.
http://dirtdevil.com/parts/category/brushrolls-uprights/
Oct 30, 2012 | Dirt Devil Breeze Bagged Upright
My roomba 550 goes round and round going know where.all the rest work ok
I have the complete service manual for the 550 series. It is in PDF format and if you would like the complete manual, give me your email address and I will send it to you. Below is the basic cause and repair for your irobot's condition.
Circling at slow, normal or rapid speed:
Most common causes: Dirt has infiltrated the wheel encoder or a drive belt has failed.
In MOST cases, the robot's software will recognize and correct the behavior within minutes. If the battery was recently reset, the robot may act erratic again at startup until the software has a chance to correct the condition. • If the Robot does not resume normal driving behavior within the first couple minutes of runtime, go to DRIVE WHEEL Module inspection and cleaning (Appendix C). If cleaning wheel modules does not correct the problem, both wheel modules may need to be replaced. • Replace drive wheel modules if fixes fail.
Happy Holidays
Dec 16, 2010 | iRobot Roomba 550 Vacuum
I have a new brush to install but cant figure how to remove old, what is the trick?
On most vaccuums, there should be a single panel going across one side of the brush wheel. If not, the entire panel should come off. In 90% of cases, this will basically allow the brush wheel to fall free, and the new one to be slotted into the old slot. Ensure the belt is connected, and reattach the panel.
Apr 23, 2010 | Kenmore 34613 Bagged Upright Vacuum
I have a bosch ergomaxx 2000w which I need to strip down and clean. Ive found 6 torx screws bit still can't remove the coloured plastic cover. How do I remove it?
Got the same !
Remove both back wheels (just pull gently with a screwdriver), then with a big screwdriver pull the cover while pulling plastic locks in the side holes (under the wheels) whith a small screwdriver.
Jan 16, 2010 | Bosch Vacuums
Roomba stops running after 2 minutes
First drain the battery completely and then take out battery and charger and hold power button for 30 seconds and then clean the roomba with compressed air take out all compartments and blow air thoroughly everywhere especially near the wheels where the wheel sensors are. Leave battery to charge for full day and try to run.
Jan 31, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba wheel -- stuck
I had a similar problem, I just took my Roomba Red apart and put it back together about four times before I fixed it.  In my case it turned out to be a dirty sensor, fixed as described at
http://mysteryroad.blogs.com/photos/roomba_gallery/xintroroomba_3549.html
Before you open it up I recommend following the diagnostic tests to see if its a physical problem (bad motor belt, hair stuck around the wheel) or a sensor problem (dirt makes Roomba think it is stuck when it isn't).  If you follow the diagnostics one of them will move the Roomba wheels while ignoring the sensors; if the wheels move fine then you probably have a sensor problem.
http://www.roombareview.com/swiftracer/roombareddiagnosticsmode.shtml
-- Ben www.benzado.com
Jul 10, 2008 | Roomba Robotic Floor Bagless Vacuum
Numatic Henry Hoover
They should just pull out with a little pressure and a pair of pliers. Good luck with your repair
May 21, 2008 | Numatic Henry Bagged Canister Vacuum
Vacuums Logo
606 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
