Hi i purchased an INTEL DG55 with core i3 processor and 4 GB RAM with 500 GB SATA hard drive , LG dvd writer. For some reason , after everything was assembled , Even when i load the windows cd , it gives a blue screen . all of the 6 setup disks do the same thing , I cleaned the RAM , swapped the sata cables and the power cables . All seem to be correctly set but , i'm not able to even get to the partitioning part. Pls advice.
  • 917 Answers
If the motherboard, CPU and RAM are working then you should at the very least get a POST screen, i.e. some text should appear on the screen for a brief moment.
Disconnect all drives and only leave the monitor connected. Power up and see if anything shows.
Check that the RAM is compatible; desktop PCs use non-ECC RAM, and won't work with ECC server RAM.
The motherboard will beep if an error is detected so listen out for beeps and check the motherboard manual to determine what error is being signalled. If the CPU is not powering up then you won't et any beeps.
Try removing the CPU and checking the pins to make sure there are no bent or broken pins.
If you have a spare graphics card, try plugging this in and connect the monitor to this card.
Try removing the 3V CMOS backup battery from the motherboard for a few seconds to reset the BIOS configuration data. Replace the battery and try switching on again.
If you can't get to the POST screen on switch-on then the motherboard, CPU and/or RAM could be faulty and you should take it back to the place you purchased it from.
Posted on Jul 03, 2017
    Habit-Forming:
    New Friend:
  • 18 Answers
If you have access to another computer you can make a bootable USB using the files from the CDs (assuming we are speaking of a bootable image file on the CDs).
If you have the Windows Backup that you created from the previous computer, that you will not be able to deploy on the new computer due to the changes in the hardware. This is most likely the reason that you get the BSOD.
Hope that helped.
SOURCE: 250gb sata hard disk to 845 glad mother board
hi am sathya,
I have oner doubt in my intel p4 845 chipset board , what are the processors in suitable in 845 chipset board.. Give me solution
Posted on Aug 18, 2008
mdsaeed67
  • 849 Answers
SOURCE: Sata drive not detected
just no other solution except upgrading BIOS properly
Posted on Oct 27, 2008
frcs68
  • 1605 Answers
SOURCE: Dell Precision 470 Dual Processor
enable "auto" in BIOS for drive #0 and drive #1. you can select IDE or SATA drive. restart the machine.
Posted on Dec 10, 2008
fffms
  • 22 Answers
SOURCE: not able to install 2003 server on dg31pr board
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
130
Posted on Mar 13, 2009
SOURCE: how did u install win xp on compaq presario CQ60 104tu?
to install xp in any machine that has an intel chipset be it hp, dell or whatever is relatively easy ....the solution is found here
go to http://downloadcenter.intel.com/ and in the search textbox type "spacer.gif32-bit Floppy Configuration Utility" then download it.
extract the content of that zipped file that is called f6flpy3287.zip .
then click on this site http://www.tacktech.com/download.cfm?file=microsoft/sata/sata-drivers.zip....here you get all the drivers for sata intel chipsets ....The content of this zipped file is similar to that of f6flpy3287.zip but its advisable you use f6flpy3287.zip contents to slipstream.
secondly download a software called winlite from http://www.nliteos.com/download.html ...its a freeware
then follow this site
http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
Altenatively ....for the ... advanced users
http://www.tacktech.com/display.cfm?ttid=411
yours karanja
karanjae@gmail.com
kenya
Posted on May 06, 2009
How do i reset the sophos safegaurd password?it opens direcetly to the sophos safegaurd
if you have lost the password and have the software for the device uninstall the software in control panel, do a disk cleanup and a defrag to clear any remnants of the software in the system files then reinstal setting a new password at the same time.
May 30, 2015 | HP ProBook 450 G1 15.6" LED Notebook -...
How much
Hi jaygomez_13,
Please check this, You can also click this link: http://www.acer.com.ph/ac/en/PH/content/series/aspire to check the price, specifications, models and other details. aspire_11_350x250.jpg Aspire AS4745G-352G32Mnks ( LX.PSM0C.037 ) 28000 PHP
Linpus™ Linux® - Intel Core i3-350M (3MB Cache, 2.26GHz) - 2GB DDR3 RAM - 320GB SATA HDD - ATI Mobility Radeon HD 5470 with up to 3579MB of HyperMemory - Screen Size 14" HD 1366 x 768 resolution - Battery 6-cell Lithium Ion (Li-Ion) 4400mAh - Up to 6hours battery life
AS4745G-352G32Mnks LX.PSM0C.037 aspire_11_350x250.jpg Compare energy_star.jpg Intel® Core™ i3 Processor
  • Operating System Operating System Linpus™ Linux®
  • Processor & Chipset Processor Manufacturer Intel Processor Type Core i3 Processor Model i3-350M Processor Speed 2.26 GHz Processor Core Dual-core Cache 3 MB 64-bit Processing Yes Hyper-Threading Yes Chipset Manufacturer Intel Chipset Model HM55 Express
  • Memory Standard Memory 2 GB Maximum Memory 8 GB Memory Technology DDR3 SDRAM Memory Standard DDR3-1066/PC3-8500 Number of Total Memory Slots 2 Memory Card Reader Yes Memory Card Support Memory Stick PRO
    xD-Picture Card
    Secure Digital (SD) Card
    MultiMediaCard (MMC)
    Memory Stick
  • Storage Hard Drive Capacity 320 GB Hard Drive Interface Serial ATA Hard Drive RPM 5400 Optical Drive Type DVD-Writer Optical Media Support DVD-RAM/±R/±RW
  • Display & Graphics Screen Size 35.6 cm (14") Display Screen Type Active Matrix TFT Colour LCD Display Screen Technology CineCrystal Aspect Ratio 16:9 Screen Mode WXGA Backlight Technology LED HDCP Support Yes Graphics Controller Manufacturer ATI Graphics Controller Model Mobility Radeon HD 5470 Graphics Memory Capacity 512 MB Graphics Memory Technology DDR3 SDRAM Graphics Memory Accessibility Dedicated TV Card No
  • Network & Communication Wi-Fi Yes Wi-Fi Standard IEEE 802.11b/g/n Ethernet Technology Gigabit Ethernet Bluetooth Yes Bluetooth Standard Bluetooth 2.1
  • Built-in Devices Webcam Yes Microphone Yes Finger Print Reader No
  • Interfaces/Ports HDMI Yes Total Number of USB Ports 4 Number of USB 2.0 Ports 4 VGA Yes Network (RJ-45) Yes
  • Software Operating System Linpus™ Linux®
  • Input Devices Keyboard Yes Pointing Device Type TouchPad
  • Battery Information Number of Cells 6-cell Battery Chemistry Lithium Ion (Li-Ion) Battery Capacity 4400 mAh Maximum Battery Run Time 5 Hour
  • Power Description Maximum Power Supply Wattage 90 W
  • Physical Characteristics Colour Black Height 29 mm Width 342 mm Depth 245 mm Weight (Approximate) 2.20 kg
  • Miscellaneous Package Contents
  • Aspire AS4745G-352G32Mnks Notebook
  • Lithium Ion Battery
  • AC Adapter
  • Security Features
  • Kensington Lock Slot
  • BIOS Passwords :
    • User
    • Administrator
    • Hard Drive
    Green Compliance Yes Green Compliance Certificate/Authority Energy Star
  • Warranty One-year International Travellers Warranty (ITW)
    Hope it helps.
    Thank You for using Fixya.
Sep 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hello everyone, Its my 1st question hope someone will help me: I hv bought DH55TC/ PJ motherboard Core I3 processor support 4 GB DDR3 RAM, I want to install windows server 2003 STD with original cd. I am...
Welcome to LG service Center we provide all type of LG laptop, computers,printers services.we are engaged in offering our clients effectual services on call & repairs of computer hardware. Our services include repairing of laptop, desktops, ups, monitors, projectors, printers and projectors. These services and maintenance work is performed by our team of experts, which is proficient enough to handle the queries and technical problems of our clients.
May 08, 2011 | Intel Computers & Internet
My LG dvd writer does not read cd or dvd
That's a lot of questions! Well, the speed at which a CD/DVD-Writer writes to a CD-RW depends not only on the media and the drive, but also on the table of media types that is built into the firmware of the writer. The drive tries to recognise the blank media inserted, and matches it with the list in its table to decide the speed. It also reads the speed certified by the media manufacturer, and if these don't match, the writer decides to use a safer, lower speed.
Another reason could be that the writer does not support the intermediate speed of 12x-for example, it may support lOx, with the next supported speed being 16x.
Your motherboard supports IDE as well as SATA hard drives of the highest capacities avail­able. You cannot add more RAM running at a different frequency, but you can certainly replace your present RAM with 533 MHz DDR2. It supports any Intel processor with the LGA775 socket interface barring dual-core processors.
Feb 27, 2011 | Computers & Internet
HI I have a desktop with : *MSI Motherboard with Nvidia chipset on it *Intel Core 2 duo *2 GB SDDR2 RAM *500 SEAGATE HDD I created four partitions on the HDD , i had bad sectors on the fourth partition...
Have you considered checking your DVD writer? Also, you might already have a faulty hard disk drive.
You can try any of the following:
1. Double check to see if your Windows 7 installation disk is dirty (clean it using a lint free cloth) or has many scratches. (Your DVD reader/writer would really have a hard time reading scratched disks.)
2. Borrow another DVD-ROM from a friend and use it to install Windows 7 on your computer's C drive.
3. Check to see if ALL cables are properly connected. i.e. SATA, power cables, etc.
4. You could also try to make your 500 GB HDD as a slave drive so that you can backup your files to another media if it works. (Backup to another external hard disk drive, burn it to DVD's, etc.)
5. LISTEN carefully if your hard drive makes unusual noises like unusual clicking, bumping, and/or scratching sound inside your hard disk drive. If it does and as a last resort, replace your hard disk drive.
Nov 23, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I want to buy a laptop. Please suggest me which processor is best? ie. Intel pentium processor or intel pentium dual core processor? Will intel pentium dual core processor overheat easily?
hello,,,,,,,,,,,,,
First you need to be clear that dual core is the family of Pentium series. so there is no processor called Pentium.............. now regarding your question i would suggest you do not go for dual core... Take core 2 duo or I3 /I5/I7 series of processor..............
I am giving you a configuration in a good budget
Rs 50,800/-
Intel 3 GHZ Core2 Duo Processor,3 GB DDR2/DDR3 RAM, and a 250/320/500 GB HDD. DVD writer, 15.4-inch display with a resolution of 1280 x 800 dpi. integrated Intel Graphics Media Accelerator X3100 video card, integrated modem and sound card, Wifi, Touchpad mouse and in-built speakers. It has interfaces like Express Card slot, S-Video port, 4 USB ports, Firewire port, bluetooth and a 6 in 1 Digital Media Reader. The laptop comes with an inbuilt camera .
It would be better if you can tell me your budget ............... So that i can give you a good configuration ......................
Jun 14, 2010 | Computers & Internet
DVD Writers can read but can not write
update their drivers: they're indicating readers, not writer devices..
Mar 25, 2017 | LG GMA-4082N DVD±RW Burner
Computers & Internet Logo
426 people viewed this question
David Payne
David Payne
