Question about Cameras
Had the camera for a year and worked perfectly fine, tried turning it on the other day and made a loud noise as it was trying to open the shutter at front but failed to. The screen told me to turn the power off and on again hoping it would fix the problem but hasn't. Since then tried numerous times in different settings like playback mode as the front doesn't open in that mode, but still no luck, please help!
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 13, 2010
Shutter is stuck open on the digital camera w1200. When i turn it on the shutter goes in a little than tries to go out and it makes this weird loud clicking noise and i cant see a screen and when it is...
I think what you're referring to is the lens assembly not moving in and out correctly. The shutter is inside the camera out of view. Go to this website for possible solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 16, 2011 | General Electric W1200 Digital Camera
When i turn the camara on it makes a loud noise like its trying to open the shutter then it doesnt focus if i zoom in or out.
there might be something in the lens. even a grain of sand to do that. try flushing it out with an air sprayer or dust sprayer.
Jul 31, 2011 | Kodak EasyShare One Digital Camera
Camera will not take pictures and I can not see anything thru
Found this on another web site. Worked for me
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority (“Tv”).
Use the four-way button on the back to set the shutter speed to 15 seconds.
Press the shutter release. Count to seven, then pop open the battery compartment. (I discovered that the camera will beep when you do this.)
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
May 13, 2010 | Canon PowerShot S2 IS Digital Camera
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
Jul 08, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Shutter release problem
Try removing the lens and the battery and leaving it for 24 hours - this can happen when the gremlins get into the works !
Jul 24, 2017 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
My camera will turn on but the shutter won't open!
tiny bits of juice, remember? maybe (or I am sure) this tiny became corrosive inside the camera. (orange juice is the no.1 in my corrosive juice list, water is the least). You need to open and clean it, or a pro fix is necessary.
Sep 09, 2007 | Olympus FE-190 Digital Camera
Clicking noise and shutter wont open
Look for Contamination on the slide Take Denatured Alcahol and Clean the Assembely Let me Know ttech
Jul 20, 2007 | Nikon Coolpix 3200 Digital Camera
D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Feb 03, 2007 | Nikon D50 Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
