Question about Martin Intimus 502 CD Shredder
Where can I get replacement on/off switch - Martin Intimus 502 CD Shredder
  • 23 Answers
Replace broken power switch
didnt specify make and model --generic answer --unless it is a mother board [newer design ] unplug unit remove knob and where switch is housed unscrew the housing than unscrew switch retaining screws unplug connector remove switch and replace the following link shows how to replace different switchs
Replace Washing Machine Switch Yahoo Video Search Results
Jul 09, 2016 | Dryers
I have a gfci/switch and need a 4 wire instructions. As none of the diagrams match what i have.
What device are you replacing... a switch or a outlet?
1) If you are replacing a switch with 3 or 4 wires?
That is either a 3-way switch, 4-way switch, or a DPDT switch and cannot be replaced with GFCI
2) If you are replacing outlet with 4 wires, then it can be replaced with GFCI combo.
http://waterheatertimer.org/How-to-wire-GFCI.html#8
3) If you are replacing ordinary single-pole switch, then you can replace with GFCI combo IF the box has a neutral wire
http://waterheatertimer.org/How-to-wire-GFCI.html#6
4) You can install GFCI protection on any circuit by installing GFCI earlier in the circuit.
http://waterheatertimer.org/Basic-house-wiring.html
Gene
Oct 21, 2014 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
Stove element always on high
If the switch is bad the contacts in the switch are not breaking allowing the switch to regulate the power to the element. The switch will need replacing. unless you are replacing the switch with an exact replacement the wiring can be tricky. many times the company will replace the switch with a different manufacture and the terminals are not in the same location. This can make replacing the switch a bit of a challenge unless you are familiar with how the switch is wired. I would have a service person do this you could short out the new switch if wired incorrectly.
Mar 10, 2014 | Ovens
Cooling fan switch
It is not necessary to replace the thermo-switch when replacing the radiator. The switch can be replaced separately.
The fan switch is located under the sound box of the air cleaner. It is 2 pin connector. Pull the connector out by pressing the lock which attached to it and short the two pins with a thin auto wire temporarily. Switch on the ignition. The fan will become on. Drive it and see if runs hot.
If the temp reads OK, replace the fan switch. If the problem persists, diagnose the other issues which are concerned with the overheating problems.
May 07, 2013 | 2003 Honda Civic
Kexus ignition switch replace
To troubleshoot these issue, for ignition switch replacing procedure:---
Click the link below:---
IGNITION SWITCH REPLACING
It depends on vehicle to vehicle. But it's not very difficult on mot of cars to replace ignition switch. Basic theory of replacing ignition switch is same for all car models. -----
To replace ignition switch on your vehicle, I suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.
Click the link below: ------
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to replace Ignition Lock Cylinder on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-lock-cylinder.html
Ford Taurus: Ignition Switch & Steering Column Replacing?
http://repairhelpcenter.blogspot.in/2012/06/ford-taurus-ignition-switch-steering.html
How to replace Ignition Switch on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-switch-on-acura.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Dec 06, 2012 | 1993 Lexus Es 300
How to replace ignition switch
It depends on vehicle to vehicle.But its not very diffult on mot of cars to replace ignition switch.Basic theory of replacing ignition switch is same for all car models.:-----
To replace ignition switch on your vehicle,i suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.-------------Click the link below :----------------
1995 Ford Taurus: Ignition switch not turning OFF? http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off? http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Nov 25, 2012 | Cars & Trucks
Remove/replace starter sloenoid
your Ignition Switch is bad here is how to replace it
The ignition switch is usually mounted to the steering column and is operated by a linkage rod.
NOTE On column-mounted ignition switches, don't confuse the switch with the lock cylinder and keys. The ignition switch is not normally visible. On some vehicles, the steering column support has to be removed and the column lowered to find the ignition switch. On others, the switch is accessible under the dash.
f32-17gif.gif The ignition switch is operated by the key switch. Courtesy of Ford Motor Company. To replace the switch:
  • Remove the ignition switch wiring harness.
  • Unbolt it from its position.
  • Bolt the new switch into position.
  • Attach the witing harness.
May 22, 2010 | Jaguar Vanden Plas Cars & Trucks
GSW-22 wall button switch
120VAC/3A is the rating of the switch. You are probably installing the switch to control a 120 volt device. 3A is the amperage capacity of the switch, which is not much. If you are replacing a wall switch that controls lights, I would recommend replacing it with a standard toggle switch. They are rated for 15 and 20 amps. Those button switches are meant to be used to control single devices.
Apr 16, 2010 | Gardner Bender #GSW-22 Push Button Switch
Was replacing the ignition switch and accidently broke off a silver piece off of where the switch goes connected. Can you some one tell me if this can be replaced and if I have to replace the entire key...
Replacing An Ignition Switch..
If The Ignition Switch Is Defective, It Must Be Replaced Regardless. Before Removing A Dashboard-mounted Switch, The Tumbler (Lock Mechanism) Must Be Removed From The Switch.Normally A Small Piece Of Wire Is Inserted Into A Hole IN The Front Of The Switch And The Key Is Turned.This Will Release The Tumbler From The Switch So The Tumbler Can Be Pulled Free. Then Unplug The Wires And Remove The Old Switch.
A Steering Column-mounted Ignition Switch Is Separated From The Tumbler. It Is Normally About Halfway Down And On Top Of The Steering Column. To Remove This Type Of Switch, Remove The Fasteners Holding The Steering Column To The Dash. This Will Let The Column Drop Down So You Can Replace The Ignition Switch.
Apr 09, 2010 | 1999 Dodge Caravan
Martin Intimus 502 CD Shredder Logo
89 people viewed this question
Top Martin Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Martin Office Equipment and Supply Expert? Answer questions, earn points and help others
