Question about LG RE-44SZ21RD 44" Analog Television
LG RE-44SZ21RD 44 whihc doesn't start
Hi
I have bought a faulty LG RE-44SZ21RD whihc doesn't switch on.When you turn the powerup there is a red light turns on the front which then turns to flashing orange when remotely turned on. This also starts the fan as I can hear it.
Can someone please help!!!
Thanks
  • 3 more comments
  • Nish1155 May 23, 2008
    Thanks for the reply but Are you sure its the lamp.Because I have been informed that it might be the power supply board.
  • wozrokka666 May 29, 2008
    Not sure it's exactly same model, had similar problem 18 mths- 2 yrs ago, had lamp replaced under ext warranty, is it easy to do yourself??
  • grabbyp90 Jul 02, 2008
    Yes, I have the same "ish" problem. For a couple of months sometimes the remote would not operate the TV whilst on or off. Resulting in a manual switch off. Then it started to not switch on at all. Sometimes the red light would come on. Sometimes not. A power off at the mains helped.Then it started to power up without any lights and the picture would eventually come on. Now, complete shutdown and no lights on, nobody home!!! Never has the lamp replacement indicator come on during the quirky times. Can anyone help? RSVP
  • tjdss Dec 22, 2008
    Hi
    i have the same problaem !!!!!!!!!!!!!!!!!!!!!!
    Thanks
  • Anonymous Apr 14, 2009
    got the same problem had it repaired two years ago on warranty now its at it again, have just reset the lamp life counter to try that, justanswer said it was power supply board and likey to be 350 to repair!
I think you'll find the lamp needs replacing
Posted on May 23, 2008
Number part colour wheel
If its a LG the color wheel is only sold as part of the optical light engine--the Zenith version uses 3 different light engines.
If you have time let me know what makes you suspect the Wheel?
Mar 16, 2012 | LG RE-44SZ21RD 44" Analog Television
It start up and sounds normal but the lamp dont light
sounds like your colour wheel has gone, not something that can be fixed yourself i'm afraid
Nov 30, 2010 | LG RE-44SZ21RD 44" Analog Television
LG re-44sz21rd How do i remove bulb ?
As you face the tv bulb is located on the right hand side of the tv,there is a door that has 2 philips #2 screws remove'em and lamp is behind the door,lamp has 2 more screws that have to be removed, carefull not to drop the screws inside the cabinet.
Mar 22, 2010 | LG RE-44SZ21RD 44" Analog Television
My LG RE-44SZ21RD tv goes off spontaneously. will come on after a long period switched off but go off again. no rhyme or reason to the issue. i thought it was some sort of software issue because just befor...
this problem seems to have corrected itself although the dark patch at the top of the set is still present.
I cannot think of anything in particular that i may have done to fix it but i have resorted to turning the TV off using the on/off switch after using the remote. Other than that i removed/replaced the bulb.
so far, it is 3 weeks and counting since i last had any problems.
Dec 19, 2009 | LG RE-44SZ21RD 44" Analog Television
I have an LG RE-44SZ21RD, turns off after 5 minutes of use
It might be worth checking that you haven't accidently activated the tv's sleep timer, I did on my LG DLP !!. always check the obvious first.
Oct 06, 2009 | LG RE-44SZ21RD 44" Analog Television
LG RE-44SZ21RD 44
This is vcaused by a relay similar to a fluro/ neon light starter switch. This part has failed so it cannot get syncronization You will neede to have a serviceman replace this part.
Please rate our help to keep the free service online
Aug 26, 2009 | LG RE-44SZ21RD 44" Analog Television
Orange light
Your Tv requires the lamp hours to be re-set. You will need to acess the Service mode settings via a service remote from your authorised LG service agent. Can be done onsite, depending on the company.
Nov 06, 2008 | LG RE-44SZ21RD 44" Analog Television
Orange light
MEANS THAT ITS TIME TO REPLACED YOU LAMP/ THAT ONE YOU HAVE MAY GO OUT ANYTIME.
Jul 03, 2008 | LG RE-44SZ21RD 44" Analog Television
WARNING LIGHT ON FRONT OF TV
Jul 02, 2008 | LG RE-44SZ21RD 44" Analog Television
LG RE-44SZ21RD 44" Analog Television Logo
715 people viewed this question
Computer Repairing
Computer Repairing
