Question about Dryers
Dryer cycles through twice then wont relite - Dryers
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 14, 2010
I have a GE dryer model #DCVH660EH3BB, it powers on but when I press the start button it beeps twice at me and won't start the cycle. The lint trap and vent have both been thoroughly cleaned.
From the manual...
Problem
Cannot make a selection and the dryer beeps twice.
Possible Cause
The DRYNESS LEVEL, TEMP or OPTION that you are trying to select is incompatible with the chosen dry cycle.
Link to your manual, troubleshooting starts on page 24.
ShopYourWay GE Residential Dryer ShopYourWay
Jul 22, 2016 | GE Dryers
**** beko dryer drvs62w
hiya my beko dsc85 8kg has stopped after finishing a cycle of clothes but wont restart just says drying but nothings happening and i have cleaned everything twice any advice on the problem would me much appreciated. thanks glenn
Nov 15, 2012 | Dryers
Dryer starts heats up then burner drops out igniter will try to relite but wont
Make sure that you check to see that the valve is not shutting the gas off to the igniter. If the igniter / pilot goes on and off itself then there is an issue with the ignitor / pilot and it will need to be replace.
Jul 02, 2012 | Whirlpool Dryers
Kenmore model#110.72702101 starts up,heats then burner stops won't relite
If what your seeing is that the flame starts out and goes off and a few later later the igniter glows but no flame??? then the cause of that is going to be the coils on the gas valve are weak and not opening. This tip i wrote explains what is wrong when a gas dryer starts heating but after a while wont heat. http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Sep 13, 2011 | Kenmore Dryers
My Neptue dryer wont dry unless I run it more than one cycle. model no. mdg5500awq. all lights work and seems to run fine it just wont dry the cloths unless I run it at least twice and jeans are three or...
Turn dryer on and go outside to the vent and check for a good amount of air coming out. If you do not have a good amount of air coming out, take the exhaust tubes apart and clean.
Jun 07, 2011 | Maytag Neptune MDG5500AW Gas Dryer
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Dryer will not relite after initial warm up
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LGR5636L&siteCd=WHRCOM
This site has 6 variations of LGR5635L, user guides, setup instructions, warranty guides and parts manuals. Also, I think there should be a wiring diagram on the inside of rear cover. Hope this hekps.
Aug 24, 2009 | Whirlpool LGR5636L Gas Dryer
Sears kenmore dryer wont run (Electric)
Sounds like the motor relay and/or the even heat board. Remove endcaps from console and remove 2 screws in corner. Pull console torwards you and up and it will flip up. The board is on the left and there are 2 relays on the right. The only difference is one has big red wires and the other has smaller blue ones. Blue wires are motor relay. Possibility of door switch also broken off.
Mar 08, 2009 | Kenmore 63942 Dryer
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
Top Dryers Experts
