Question about Epson Stylus 830U InkJet Photo Printer
Jet clogging the jets are clogging very frequently , what is causing this and can it be fixed ?
  • sme3s Jun 12, 2008
    I have just the same problem if I haven't used the printer for a day or 2
    Scholar:
  • 83 Answers
Clean the printer head with a cloth or absorbent cotton or clean tissue. It may have been clogging because it was not use for many days. It needs cleaning always when printer was not use for a longer period of time.
Set your printer to cleaning then test print. if same problem persist perform deep cleaning. I have tried it many times and It works.
Posted on Nov 28, 2008
How do I fix a jet that isn't hardly pumping on my Aqualux jet tub? The other 8 jets work but no more bubbles. Is it the switch? Is that one jet clogged? Do I need a new pump? How do I get the jet out
hello Tami!
That particular jet is probably clogged.
You can find special cleaners NON ABRASIVE at your local hardware stores.
Be sure to tell them what cleaners you are looking for to make sure it is a non-abrasive type.
Or call in for service. Here is a link that may be helpful to you.
Best of Luck,
JP
Bacteria Alert How To Easily Clean Jacuzzi Bathtub Or Whirlpool Tub Hot...
Oct 28, 2015 | Home
My jets are humming In the lasco luxury bathware how do I fix
The humming suggests that the pump is running but something is clogging it. You will have get access to the pump and probably do some disassembly to isolate the cause and correct it.
Jan 26, 2015 | Home
Kawasaki zx9r ninja e1 spluttering at low speed but ok at top end
Hi Shaun, This could be caused by several things, but the most common cause is also probably the most common problem with carbureted bikes in general, and that is one or more clogged idle jets. Any time a bike isn't put away properly for the winter, it runs the risk of stale gas drying up and clogging the idle jets. The good thing is, this is a pretty easy fix, but it entails pulling the carbs, then taking the bowls off and squirting carb cleaner through the jet to dissolve the clog. In a worst case scenario a very fine wire can be run through the jet to clear it. To save yourself some time, let the bike idle then see which cylinder isn't firing by squirting water on each exhaust to find the cold one (or ones).
Jul 06, 2014 | Motorcycles
Cannot keep fence square to bed it keeps moving. Jet JJ8CS what could be causing this?
The clamp on the near end can be tight but the one on the far end tends to loosen unless you really tighten it and check frequently
Mar 06, 2013 | Jet 708458K JJ-8CS 8-Inch 2 Horsepower...
1963 vw newly rebuilt engine, starts then dies at RPM acceleration
Could be one or both of two things.
1. The accelerator pump in the carb is clogged, the linkage is unhooked, or the diaphram in the pump is bad. It's cheap to replace and comes in the carb rebuild kit. This usually just causes hesitation when you step on the gas pedal. It doesn't usually cause the engine to stop running.
2. More likely is that the main jet in the carb is clogged. At idle, high vacuum under the closed throttle plate in the carb causes fuel to flow thru the idle jet. As the throttle plate opens (as you step on the pedal), the vacuum under the plate dissipates, stopping the flow of fuel thru the idle jet, and the vacuum ABOVE the throttle plate increases, which is supposed to then draw fuel from the carb bowl thru the main jet in the carb. If the main jet is clogged with dirt, then it can idle just fine and die as soon as you step on the pedal.
Jul 24, 2011 | 2000 Volkswagen Beetle
I have installed a brand new 4 hp pump and a brand new Balboa heat and control package. I have wet vacuumed all the jets and removed filter. Pump is still weak and kicks off after awhile. How do I...
most of the jets in a Hot Tub are adjustable. the face of each jet can turn on/off. Make sure they are all open or you will not have good water flow and cause too much back pressure on the pump and cause it to fail.
check the jet faces when you turn the pump on.
also a dirty filter will cause low water flow so check that too. take it out and see what pressure you get through the jets.
Jan 29, 2011 | Home
Samsung Jet S8003 Hangs frequently.
what is the S.W version you have?
please feeb back
Apr 14, 2010 | Samsung Jet S8000 Cell Phone
Plug fires but still can not gewt saw to fire
frequently the carb jet is clogged .. especially if gas was left in over the winter .. you can get some "starter fluid" spray a little on the air intake filter .. then see if it starts .. if it does it might work loose the clog in the carb .. you might have to do it over several times .. if it runs for a little while on the starter fluid but wont keep running then you may have to remove and clean the jets in the carb .. be very careful not to scratch the jet hole ..that can happen if you try to force a small wire thru the hole .. a scratch will change the mixture ... sometimes its easier to buy a new high speed jet and replace it rather than trying to clean it ..
Aug 17, 2009 | McCulloch Garden
Choke on
Sounds like your idle jet is clogged. This is caused by gasoline evaporating out of the carburator during long periods of disuse which can leave a varnish residue. You will probably need to remove the float bowl and remove the jet to clear it as carb cleaning additives in the gasoline are usually useless for this problem. It is vital that you use the exact fit screw driver on float bowl screws as they are usually very tight. The jet will have a very small opening and you could damage the jet if you use the wrong method to clean it (do not use a drill bit). First try a carburator cleaner spray with the small plastic straw that comes with them. Look thru the jet hole by holding it up to a strong light to see that it is indeed clogged. Then try holding the small straw in the jet orifice and forcing the cleaner into and through the jet. Be careful that you don't deflect the spray back into your eyes. Use eye protection. You could try to soak the jet in a cap full off the cleaner for a while. If that doesn't work a very small stiff wire might work to push the clog out (from a wire brush?). Then try the spray method again.
Nov 10, 2008 | 2004 kawasaki KLX 400 R
Epson Stylus 830U InkJet Photo Printer Logo
209 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
