Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Drive belt keeps coming off. What size belt is correct for this mower? I have been using a 1/2 x 30" belt. I don't have a manual so tried to measure the old broken belt. Belt seems to come off when I shift into gear. Would a 3/8 x 29" be better? The 1/2" seems terribly hard to install. This is a Craftsman ii ride-n-mulch 10hp mower (30 inch mower) model # 95052-033919
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
  • 376 Answers
SOURCE: Craftsman 19hp won't move when in gear
There is a square key about 2 " long that fits in the slot on the axle and wheel and locks them together.. You probably didn't see it when putting tire back on and knocked it out. If you go back where you removed tire, you'll find it laying on the ground.
Posted on May 27, 2009
Tensioner belt keeps slipping off front pully
Everett, Do you mean drive belt keeps coming off front pulley?
Possible causes, accumulated dirt/debris above deck or on trans axle, damage,stretched,wrong size belt, belt tensioner seized/missing spring if equipped, belt retainers/guides/keepers damaged /missing/ adjusted to far from pulley, damaged/worn pulleys, loose engine, belt way out of alignment,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Are the Causes of Belt Coming Off Riding Mower
Drive belt keeps coming off when shift into reverse
Need help with mower deck belt keeps coming off Craftsman LT2000...
belt keeps popping off
Jul 20, 2016 | Garden
Why after fitting a new belt on my hrx476 mower does it still keep coming off
Make sure the belt is in line and the idler pulleys are free and not seized and check the adjustment is correct might be the back axle is slotted for the adjustment.
Mar 29, 2016 | Garden
Install drive belt for scotts s1642 rider lawn mower
check size of belt make sure its correct make sure routing is correct andput belt on tension pully last you may have to pull on it to get it around it
Aug 30, 2012 | Garden
Model no. 917257660 need belt size for drive and deck
The part number for the drive belt is: 140294 the size is Length: 82 1/4", Width: 1/2", Type: Covered
The part number for the mower deck is: 140067 the size is Length: 82 1/2", Width: 1/2", Type: Covered
They are very similar belts so don't get them mixed up the springs on the clutch pulleys may not be able to compensate for the slight difference.
Good luck, if you find this helpful please vote yes. Thank You!!
May 11, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What size replacment belt can I but for a 54inch cut cub cadet mower. And is there any suggestions on how to keep the belt from slipping off?
they changed the part number for that belt new # is 954-3068 B x 110.6 your old belt was probaly streched so when you install new one it should ride on pulleys correctly
May 05, 2011 | Cub Cadet Lawn Mower Deck Drive Belt...
I have a troy bilt pony and the drive belt to engage to blades keeps coming off. I have replaced the belt and the pully what else could it be?
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Apr 05, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I need to replace the belt driving the mower blades but do not know the correct length of the belt?
My name is Dane and I am going to try to help you solve your problem. I believe you have mower model# 917.287220 That belt should be part number# 197253 and the belt should be
1/2" x 101-1/4" size.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thank you! Dane
Dec 04, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
42" craftsman mower deck belt 144200 to tight on the deck
Manual lists the incorrect number for this model! i learned through many difficulties. Correct belt is a # 144959, 1/2 " by 95"
Aug 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
67 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
