Question about Kenmore Washing Machines
Error message dl. sometimes 11 the an F. If I keep playing with it and re set the power sometimes I can get it to work. It ssems to have something to do with door . Also a clicking noise but no connection.....
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
My fifa 11 no working e001 problem
Fifa 11 Demo PC E0001 Error Issue
Fifa 11 E0001 error happened to a PC with this or a similar Specs: Pentium dual core, integrated Intel graphic card, 1GB of RAM, 128 of vid RAM, 2.0 pixel shaders.
Fifa 11 Demo PC E0001 Error Issue Fix:
1. Fifa 11 requires a shader model 3 or better card. That is error E0001 will be fixed and you can play this game again.
So if you get an error message as E0001 while playing Fifa 11 on Windows 7 or other systems, you should first set to the shader model 3 of your card.
2. This E0001 error issue may also be related to the graphic card that you are using. Check the drivers you are using for the video card. Update and reinstall it if necessary.
3. Get the latest driver pack for the same and then process out for the implementation. You can download the current new AMD catalyst 10.9 graphics card driver here. Or NVIDIA ForceWare 260.63 driver if you are using a Nvidia card.
4. Change the resolution to have a try. Some users get the E0001 error fixed for Fifa 11 by trying the 1280x1024 resolution on his computer.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
Jan 23, 2011 | Cisco IOS IP/FW/IDS 12.2(11)T...
My Acer Aspire 5100 8X DVD±RW DL Burner Drive UJ-850 dvd burn only small files, don't burn movies completly. Itried with several programs like nero , image burn,gburn, etc....sometimes works well, the...
Instead of trying to remove the internal drive, which is still useful, do what I did and buy an external DVD drive, just plug it in with a USB cable...then you still have your internal for nornal stuff and you can move the external around anywhere to take care of the heavy duty stuff...good luck..pls rate this solution.
Apr 23, 2009 | Acer Computers & Internet
Getting Error Message during game play.
There is a guide that you can get that will solve all errors like this and black screens it has been a lifesaver for me. Have a look at http://www.freegamesforwii.info/?cat=11 they have info on where to get this guide. I cant remeber the site off the top of my head,.
Hope this helps
Mar 03, 2009 | Nintendo Video Game Consoles & Games
F/DL Error Code
Starting with F 11 which is a serial communication error. I would pop the top by removing the three screws from the back top and look down the right front side and look with a bright light for any thing broken or loose. Then I would unplug the washer and trace the power connect back to the ccu, usually has three pink wires and also the two with blue wires. Although it has a serial error sometimes the power is corrupt because the connect is loose or corroded. I would un plug and re plug the three sets of cables, the blue usually have ds or ds1 as a label, the second is replacing the latch/lock/ sensor and doing the plugs.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1094190&PPStack=1
Here is a link with part info.
Aug 12, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
CD changer problem
According to the manual, error 11 means the disc is inserted upside down.
Oct 11, 2007 | Pioneer CDX-FM1289 12-Disc CD Changer
Washing Machines Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
