Question about Archos Gmini 400 (20 GB) Digital Media Player
Mon archos Gmini 400 ne s ' allume plus. quand j appuie sur le bouton d allumage, la led verte s 'allume tant que je reste appuyé et s ' éteint quand je relache le bouton. rien ne se passe. le disque dur ne boot pas. Existe t il une procedure de reset ?
SOURCE: Gmini XS 202s wont turn on properly....
I heard of that problem, it could be your charger circuit and it could be your battery. There's a interesting forum post on this at www.newmp3technology.com: http://www.newmp3technology.com/forum/viewtopic.php?t=700
But here's something else: I'll buy your xs202s if you want.. :)
For a reasonable defect-price.
I have one but the display is broken.
Had no luck trying to find that obscure 2" 128x128 backlit greyscale korean display in the IC-market here in Europe.
Posted on Oct 29, 2007
SOURCE: archos gmini 402 camcorder
Try turning the unit on with the hard drive disconnected. When I did this (mine had a similar problem) a screen came up and asked me if I wanted to format. I plugged the hard drive back in and reformatted. I had to format twice, but after that it worked fine.
Posted on Jun 25, 2008
SOURCE: Archos screen only
solution found!!!!!!!!!!!!!!!!!!!!!!!!!!! thank you so much for the support of the Archos team. here is what i did to repair my 504
if your "reset" button doesn't help at all, this is what you'll do.
If you power on the unit by pressing and holding the TV/LCD button and power
button simultaneously the unit will boot into a recovery screen. Once in this
screen choose "Repair Disk" and follow the on screen instructions.
When prompted, please place the following file into the 'root directory' of
the unit:
http://update.archos.com/4/a504/a504_r1.6.53/a504.aos
before i found this solution, i've already given up on my 504, but now it's back!!!! REBIRTH!!!
thanks once again to Tony H from Archos Technical Support
Posted on Aug 05, 2008
SOURCE: archos gmini 400 battery replacement
yes it does.
Posted on Aug 16, 2008
SOURCE: Gmini hard disk reading problems
My Gmini XS202s did this twice both time cause the battery went flat while moving files across (I should always charge device while connecting to PC)
First time I reformatted device as FAT32 using fdisk (Windows formatting tool should do same)
Then downloaded latest AOS and copied to root directory. [get AOS from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en]
second time I ran mkdosfs /media/disk (disk was mount point for gmini). This seemed to fix the device and I lost about 20 files. but better than reformat.
Posted on Apr 29, 2009
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
Message d'erreur oooofeoo comment l'enlever faut il changer la batterie
Vous pouvez essayer de le réinitialiser en appuyant sur tous les boutons sauf le pouvoir et les boutons directionnels alors qu'il est allumé. Cependant, ce n'est que temporaire. Plus que probable que vous devrez faire réparer. Le code 0000FE00 signifie qu'il a du mal à communiquer avec la puce NAND. Si tel est le cas, la puce NAND pourrait être absent, il peut être rompu trace, ou votre CLK a court-circuité, donc changer la batterie peut ne pas suffire. Mais si vous voulez remplacer la batterie, suivez les 2 images ci-dessous. Je m'excuse d'avance pour toute erreur de traduction, que je suis américain et mon français n'est pas très bonne.
g6dlrvzpjeebldqs.mediumd2suhqut3ynfs5sm.medium
Mar 07, 2011 | Nintendo DSi XL Burgundy
J'ai un code erreur 5200 .... quoi faire ?
Ce code d'erreur vous dit que l'unit? de purge n'a pas compl?t? un bon pouvoir sur le cycle et la came n'est pas dans la position correcte. Typiquement ceci signifie que l'unit? de purge est enfonc?e prolong? en raison de l'accumulation de beaucoup d'a s?ch? de l'encre.
Ouvrir la couverture et quand la t?te vient au centre, tirer le cordon d'alimentation. Une fois ce pouvoir est de peut vous transf?rer maintenant la cal?che ? l'extr?me gauche si c'est ? un endroit o? il ne vous g?nera pas. Maintenant utiliser une serviette en papier et tacher doucement toute l'encre suppl?mentaire de des Coussins d'encre et les appuie en bas. Si la lame d'Essuie-glace est ?tendue, le nettoie et il devrait claquer de retour en place. S'il est toujours enfonc?, essaie vaporisant le secteur avec Windex mais n'importe ne lequel obtient pas sur n'importe quoi sauf les coussins.
Nouvel An heureux !
Si je pourrais ?tre de plus ample assistance, me permettre de savoir. Si ceci aide ou r?sout le probl?me, s'il vous pla?t l'?valuer et donner un t?moignage pour ma r?ponse.
Merci, Joe
Jan 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
Comment puis-je changer l'heure
  1. Alllume ton GPS.
  2. Tape quelque part sur l'écran. Des icônes apparaissent.
  3. Cherche celle en dessous de laquelle est écrit 'Change preferences'. L'icône en question représente une clef plate (de mécanicien) .
  4. Tape l'icône pour changer la configuration.
  5. Utilise la flèche qui pointe à droite. Continue jusqu'à ce tu parviennes à la page où il y a l'icone d'une horloge (réveil-matin).
  6. Tape cette icône.
  7. On te demandera de choisir entre la représentation de 24 h (18) ou 6 pm. ou 6. Choisis ta représentation horaire.
  8. Dès que tu appuies sur Done, l'écran change et on te demande de régler l'heure.
  9. Tu as des flèches vers le haut et des flèches vers le bas. Deux flèches pour changer l'heure et 4 flèches pour changer les minutes.
  10. Tu peux même synchroniser l'horloge sur les sattelites en appuyant sur sync.
Jul 19, 2010 | Tomtom ONE GPS Receiver
Mon Lecteur MP3 Apple iPod classic 80GB ne fonctionne pas
Réinitialiser Pour réinitialiser votre iPod: * 1. Basculer le commutateur Hold sur et en dehors. (Positionnez-le sur Hold, puis désactivez-le à nouveau.) * 2. Appuyez sur la touche Menu et du centre (Sélection) simultanément sur les boutons jusqu'à ce que le logo Apple apparaît, environ 6 à 10 secondes. Vous devrez peut-être répéter cette étape.
Astuce: Si vous éprouvez des difficultés de réinitialiser votre iPod, placez-le sur une surface plane. Assurez-vous que le doigt qui appuie sur le bouton de sélection ne touche une partie de la molette cliquable. Vérifiez également que vous appuyez sur le bouton Menu vers l'extérieur de la molette cliquable, et non vers le centre. * Si les étapes ci-dessus ne fonctionne pas, essayez de connecter l'iPod à un adaptateur secteur et branchez l'adaptateur dans une prise électrique, ou connectez l'iPod à votre ordinateur. Assurez-vous que l'ordinateur est allumé et qu'il n'est pas d'aller dormir.
Si ce permis de résoudre votre problème, vous avez terminé.
Si ne pas essayer cette
Si ne pas essayer thisRetry votre iPod avec un autre port USB de votre ordinateur, pas un port USB de votre clavier ou un concentrateur.
Si ne pas essayer ce redémarrage Redémarrez votre ordinateur et assurez-vous que vous avez le logiciel dernières mises à jour installées. Note: * Pour mettre à jour vos logiciels Windows, sélectionnez Windows Update dans le menu Outils d'Internet Explorer. * Pour mettre à jour vos logiciels Mac OS, sélectionnez Software Update dans le menu Pomme.
Réinstaller * Pour mettre à jour et réinstaller votre logiciel de l'iPod, commencez par télécharger la dernière version d'iTunes. * Ensuite, ouvrez la nouvelle version d'iTunes et connectez votre iPod à votre ordinateur. * Sélectionnez votre iPod dans la liste Source et cliquez sur "Vérifier les mises à jour" sous l'onglet Résumé. iTunes vérifiera si votre iPod doit être mis à jour et effectuer la mise à jour pour vous. * Si cela ne résout pas le problème, essayez de désinstaller complètement iTunes et de réinstaller la dernière version d'iTunes.
Restaurer * Note: étant donné que la restauration efface l'ensemble des morceaux et des fichiers sur l'iPod, assurez-vous de sauvegarder tous les fichiers que vous avez enregistrés sur le disque iPod. Toutes vos chansons, vidéos, podcasts, livres audio et jeux peuvent être chargés à votre iPod à condition que vous les avez stockés dans votre bibliothèque iTunes. Comment faire pour restaurer votre iPod: * 1. Assurez-vous que vous avez réinstallé la dernière version d'iTunes. * 2. Ouvrez iTunes, puis connectez votre iPod à votre ordinateur. * 3. Après quelques instants, il apparaîtra dans la liste Source dans iTunes. Si l'iPod d'affichage ne montre pas les «Connecté» ou «Ne pas déconnecter" vous pouvez avoir besoin de mettre l'iPod en mode disque pour continuer. * 4. Sélectionnez votre iPod dans la liste des sources et vous verrez informations à ce sujet figurent dans l'onglet Résumé de la fenêtre iTunes principal. * 5. Cliquez sur le bouton Restaurer. Vous serez invité avec des options de restaurer un ou plusieurs qui peuvent rapidement iTunes pour télécharger automatiquement de la dernière version du logiciel iPod. Les 4 options de restauration possibles sont:
Si cela ne résout pas votre problème, alors vous pourriez essayer d'appeler l'assistance Apple
Sep 27, 2009 | Apple iPod classic MP3 Player
In french :la mélodie de mon tél.CD135 ne se déclenche plus et je ne peux donc recevoir d'appel mais je peux appeler
bonjour,
C'est possible que vous avez appuyé par inavertance sur le bouton "muet" ou silence. Chechez dans votre livret "mode d'emploi" pour
ce bouton
Sep 14, 2009 | Philips Lands Phones
Telecommande
Sur la télécommande, appuyer les boutons ENTER et numero 2 pendant plus de deux seconds et voila!
Bon chance.
Mar 05, 2009 | Panasonic DMR-ES10 DVD Recorder
Mon appareil canon ne marche plus!
Salut
Desole, mais mon francais est tres mal... Votre objectif a été endommagé dans la baisse et doit être réparé ou remplacé.
J'espere que ceci aide.
Thomas
Sep 19, 2008 | Canon PowerShot A550 Digital Camera
Archos Gmini 400 (20 GB) Digital Media Player Logo
54 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
