Question about Keurig B100 Coffee Maker
As soon as i switch on the power the power is tripped
    Sergeant:
    Novelist:
  • 193 Answers
What exactly is tripping out? Most kitchens now have GFI recepticals. There is a small red button that pops out if the circuit detects moisture inside the electrical parts of the coffee maker. If that is tripping you may be able to simply dry out the coffee maker by turning it upside down and then blowing the switch and electronic controls with a hair dryer for a few minutes. Try the coffee maker is a receptical in the bedroom. If it doesn't trip there it is probably moisture caused by spilling a little water on the machine when you were filling it. If it trips the bedroom breaker, it is most likely a dead short in the machine. Normally it is not worth the labor and parts to repair this machine.
Posted on Sep 13, 2010
I have a triton t100xr shower as soon I press the on switch the power keeps tripping off, please can you help?
Chances the trip switch is not high enough,as in it may need a higher amp than what has been installed.You should be able to check this out by looking at the fuse board.If memory serves me right it should be 40 amp.Check this out in the paperwork that came with the shower. If not contact Triton, they are most helpful & easy to deal with. Their number can be got on Triton site. Be VERY careful when touching any wiring either @ the fuse board or the shower.
Apr 24, 2014 | Home
Asko d1756 power trips when door is closed
The switch in the door may have a bare wire touching the sides causing a short. Check a schematic for the proper way to remove and test the switch. Look for bare wires or any insulation cracks.
Mar 15, 2014 | Dishwashers
As soon as tit went to the baking process it trip the power
you have a short circuit : God bless you
test a) door switch b) power cord c) diode power d) high capacitor e) magnetron f) thermall short a g) control board in short h) Transformer in short i)fan motor shorta5842f2f-6344-411f-a460-cd95076f5e60.gif
Oct 25, 2013 | Microwave Ovens
Whirlpool fridge freiezer keeps tripping power
Does it run for a while than trip the power or does it trip it as soon as it is turned on?
Jan 30, 2013 | Refrigerators
Model is Candy Alise 1200 SE fault is, trips house earth leakage breaker as soon as washer power switched on!
Short circuit on machine Disconnect the heating element located at the back of machine pull off the two wires then try switching on for fault, hope it clears......
Jun 13, 2011 | Candy Washing Machines
As soon as I switch on my westinghouse refrigerator, power tripped.
hi compressor may be shorted out if you know how take wires off of the compressor plug in and turn on if braker doesn't trip its the compressor . if you don't think you can do this. don't call a service tec jim
Oct 08, 2010 | Westinghouse Refrigerators
My LG WD-1049C has suddenly starting causing our power to go out and the safety switch flicks on/off. Doesn't appear to be any water leaking out. No error message displayed.
Hi just read your posting.Does your machine trip the power as soon as it is turned on or after it has been on for a time?Usually on the front loaders it is the heating element that trips the safety switch.Have you tried setting the wash temp to a cold wash?Please reply with additional information and I will help you as much as I can.Looking forward to your reply.
Sep 18, 2010 | LG WM-12230FB Front Load Washer
My Breville BB380 Breadmaker trips power switch when going baking
When was the last time that you used the bread machine? If it has been in storage for a period of time, it is likely that the element has absorbed moisture. As soon as it starts baking, the element goes into action, and because it's "leaking to earth" the machine will trip your circuit breaker.
I recommend taking the machine to your local Breville Service Centre (locate via http://www.breville.com.au/care_agentsearch.asp) as the machine is still quite repairable. If the Service Centre is unable to dry out your element though the elements are no longer repairable.
May 22, 2010 | Kitchen Appliances - Others
My machine flicks the mains switch as soon as i turn it on, both washing and drying. it first flicked the safety switch about halfway through a dry load...what could it be?
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
This sounds like a heater issue since it's tripping the power on both the wash & dryer, in events of overheating the machine will trip your power for safty & to prevent the risk of fire however since you mention that it trips the power as soon as you switch it on you could have a blocked pump or burnt out motor too if your finding that the machine is tripping the power earlyer & earlyer each time you retry i would focas on the motor or the pump 1st
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys..
remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Apr 22, 2010 | Hotpoint Ultima WD72 Front Load...
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Keurig B100 Coffee Maker Logo
550 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
