Question about Mtd FASTATTACH MANUAL SLEEVE HITCH
How to set/adjust clutch on riding mower - Mtd FASTATTACH MANUAL SLEEVE HITCH
  • 1,041 Answers
Try this site: http://www.jackssmallengines.com/MTD_parts_index.cfm
It should help.
Jim
Posted on Sep 13, 2010
Mowcart 66 break/clutch dosnt work properly and chain keeps coming off
Loosen adjuster plates where rear axle mounts to frame,they should be elongated slots to allow chain to be adjusted and alig ned,you can also adjust belt under body for clutch/brake function..
Jul 25, 2014 | McCulloch Riding Mower Briggs 20 HP V-Twin...
How to adjust brake/clutch on mtd riding mower
Go to MTD website and download owners/or repair manual for your tractor ,then adjusting the brake will be easy !
Jun 29, 2014 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Clutch chatter - Replacing the drive belt helped a little. Is there a way to adjust the clutch?
there is no clutch as far as I know on ride on mowers, there is just a tensioner pulley that works off the brake/clutch, to adjust it you have to depress the brake/clutch to take the tension off the belt then adjust the belt tensioner to apply more pressure on the belt. Also check the tensioner pulley as I have found that they split in two and the belt becomes loose as a result.
Hope this helps
Oct 20, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
Adjust clutch pto
normally they work by spring lock system, follow the bar under the hood or engine and check if any broken or missing spring or parts often bended by running over things
Aug 08, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Need to adjust rubber drive clutch on 30 inch snapper mower
there are small metal beads on the cable near the pedal you move to the other side of the pedal if the friction wheel is warn you will need to replace it only 3 nuts hold it on just flip the mower up on the rear bar and take it off no fancy tools needed
Jun 28, 2012 | Briggs & Stratton Snapper 5900748 355Z...
Poulan riding Mower Jerky Trans
there should be a adjustment on the rod to the release pulley
May 20, 2012 | Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Countax K14 ride on mower the cutter deck
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Garden
Mtd FASTATTACH MANUAL SLEEVE HITCH Logo
847 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
