My kenmore elite calypso has a code of ce - Washing Machines
  • 6 more comments
  • busy74 Sep 13, 2010
    That link doesnt say anything about code ce
    President:
  • 632 Answers
The code means there's a loss of communication between the machine control and the motor control. It is either due to a bad communication wire harness connection between the two controls, bad power connection from the machine control to the motor control, the motor control is dead, or the motor is bad. Here's the tech sheet for your reference.
Raise the control panel in the service position to access the motor and the machine controls and check for any of those conditions mentioned above. Check to make sure the connections between the two controls are good and the connectors and terminals are free from any sign of degradation; the 5-wire harness is for communication while the 2-wire is for power. Replace the harness if such condition is found.
Check the motor control for signs of electrical damage such as blown fuse and burned components. laso check to make sure that there's power going to the motor control through the 2-wire harness. Power to the motor control is relay activated so it can on;y be checked when the machine control calls for the motor control to run the motor.
Perform the checks and tests above then post back the results or finding for further help. Please accept the solution if you find it helpful. The credit will be given to the first solution if you do not accept any of the succeding solutions. Accepting the solution still allows you to post further questions and clarifications.
Posted on Sep 14, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link to have a detailed idea about the ‘ code CE ’ regarding your query :-
http://www.applianceaid.com/calypso-codes.html#wash
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 13, 2010
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
Kenmore Elite Calypso top loader and error code ce
Com error between control and motor. See page 51. Check for corrosion on the pins at the quick connect. Check for broken wires
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 16, 2011 | Kenmore Elite HE4 Electric Dryer
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
May 09, 2010 | Washing Machines
Washer won't start. shows CE on the display
That is a communication error between the control and the motor board.
Could be a corrosive buildup on the ribbon connectors and/or a bad wire or loose wire.
You can unplug the machine and trace all wires to look for a pinched or loose wire.
Unplug and clean all wire connections.
If that does not work it will be a bad motor controller.
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite calypso 24082 error code CE
On the ccu, the board on the right is usually the culprit, I have recently replaced one with that same error but I would first unplug it and remove and re connect each plug on the board looking for dark connections or dialysis, corrosion. If not fully insert each plug and try again.
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
