Question about Danze D305758 Parma Roman Tub Faucet with Soft Touch Personal Shower - Chro...
The diverter valve on this roman tub faucet is stuck- no water will flow from either the spout or from the diverter sprayer. Can this valve be disassembled and unstuck, or does it need a rebuild kit?
  • 14 Answers
SOURCE: trying to remove cowell from Roman tub faucet
The Price Phister Roman tub spout needs to be tightened from beneath.
If you do not have a removable skirt on the tub it will be a bit difficult to tighten.
Should you have crawl space under the tub and are careful to locate the dead space between the tub and the skirt you can cut a hole beneath the valve and spout location and reach up from below to tighten the spout.
If you have tile as a surround and no access from below you will have to remove some of the tile in order to gain access.
You may want to call in a proffessional plumber to handle this.
Hope this helps,
sanray
Posted on Dec 27, 2008
  • 92 Answers
SOURCE: Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Posted on Apr 16, 2009
  • 23 Answers
SOURCE: Leaking valves in new roman tub faucet installation
take the valves out and check the valve seats use flashlight if they look good then very carefully put your finger in and feel for any burrs when in doubt just replace the seats this is always a good practice when replacing valves
Posted on May 12, 2009
SOURCE: danze sonora roman tub personal shower stopped
I had the same problem and just now fixed it.  Remove the faucet head - the tub filler - and pull out the diverter tube insert.  It's the valve at the bottom that's sticking - probably because of calcium or mineral deposits.  I washed mine with white vinegar and pushed a wooden spoon handle down the tub to unstick the valve, scrubbed it with vinegar and a toothbrush and re-installed.  Works perfectly now.
Posted on Jul 14, 2009
  • 297 Answers
SOURCE: Tub shower diverter stem on tub spout broke and
you must replace the whole stem.you can get it at homedepot. first take the cover off over the stem. this should screw off or is held on with a allen key.then unscrew stem from valve body.make sure water is off to tub,just in case.
Posted on Jul 15, 2009
Water comes out of kitchen tap then slows down to nothing at all comin out
If the aerator is clear of debris, there is a valve of sorts in the center of the faucet that diverts water to a spray nozzle (the sprayer on a hose that would be next to the faucet). Even if you don't have the sprayer, most all kitchen faucets have this diverter valve. It's a bit like the thing (in a bathtub/shower combination) that switches the flow from the tub spout to the shower head.
Sometimes, something will work its way into the diverter so that it stops the flow to the tap. It could be a piece of debris (mineral flake, rust flake, etc.) that can be backflushed out. This would require removing the faucet and removing the main valve assembly. Long story short, think about replacing the faucet if the diverter valve is acting up.
Mar 12, 2011 | Washing Machines
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
Single lever with pull out accessory sprayer. Too little flow from the main spout. The pull out sprayer has more pressure than the main spout. I suspect the diverter valve is the trouble. What is the...
The Diverters Parts is C7005. Here's the parts breakdown for your Rohl faucet. Contact Rohl and have them send you new diveter for free, the A3608 seriers came with a limited liftime warranty.
Sep 17, 2010 | Rohl A3608/11LMAPC Single Lever Country...
Moen shower valves are failing
the diverter is stuck. you have to move it up and down to free it up. the diverter is the mechanism attached to the tub spout that switches the water from shower to tub. you may also need a new diverter if fiddling with it doesn't work.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
My delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Sep 28, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Danze sonora roman tub personal shower stopped spraying, no kink in hose, no plug in sprayer
Jun 27, 2009 | Danze D303754CSN Sonora Roman Tub Faucet...
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
My divertor switch/knob is not working
sound like the diverter is piped in backwards.
Mar 24, 2009 | Plumbing
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Danze D305758 Parma Roman Tub Faucet with Soft Touch Personal Shower - Chro... Logo
105 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
