Question about Cell Phones
Iphone a88 trouble
Can any1 help me solve my a88 problem. it seems that itunes doesn't recognize my a88 and i can't get them sync. help me pls, any other advice is welcome
ViewFinder
  • 33 Answers
SOURCE: Iphone "There is not enough memory available"
There needs to be sufficient disk memory on the PC to hold the contents of the iPhone (8GB or 4GB) plus some extra. This is because the iTunes backs-up the iPhone before the restore. Check and clear some space on your PC hard drive and try again.
Posted on Sep 07, 2007
SOURCE: help me pls. i cannot put my playlist from my itunes to my iphone
click on iphone in itunes then go to music, check Sync Music and press apply an you should be good to go
Posted on Sep 23, 2007
  • 4 Answers
SOURCE: IPhone SBCglobal email set up
for pop - you need to type in pop.mail.yahoo.com and smtp - smtp.mail.yahoo.com.  put in ur user name and password, it should work.  It worked for me. Make sure you have a data plan or can access the safari.
Posted on Jan 08, 2008
no_pc-gst
  • 58 Answers
SOURCE: iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
http://www.apple.com/support/iphone/troubleshooting/phone/
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode iPhone display freezing? iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with iTunes on PC or Mac? Cannot make or receive calls, send or receive text messages, or access email or the web? Or worse, iPhone simply won’t turn on and does not respond to tap or button press? If the problem still persists after you have reseted the iPhone, or tried various iPhone troubleshooting, it may be worthwhile to invoke recovery mode to restore iPhone to default factory settings, the original state as when you first received and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related
http://www.mydigitallife.info/2007/10/04/reset-and-restore-iphone-to-original-default-factory-settings-with-recovery-mode/
Posted on Jan 02, 2009
SOURCE: Error code #13019 iphone not syncing w/itunes
I googled this question and found out a lot of people are having this problem. Check this thread out for the solution. It worked for me.
http://support.apple.com/kb/TS2830
Posted on Jul 17, 2009
How to I sync my phone to itunes
Plug it into your computer with the power cord it should sync itself or give you options to sync
Dec 13, 2015 | Apple iPhone 4S
My iphone 4s is fake how can i download apps
download apps on computer through itunes and sync. if phone is recognized problem solved. if not buy real iphone. either way problem solved :-)
Oct 31, 2013 | Apple iPhone 4S
How to solve if my iphone 3G cannot be on, it stuck at the apple screen?
  • The quickest way to fix your iPhone 3G is to sync it to a different computer. When you do this the computer will recognize it as a new device and install the software on it like it's never been used before, that said everything you have on it is gone. It may take a while so be patient.
  • 2 If step one is successful you can sync it to your computer. It will recognize that it is synced with another computer and ask you if you want to sync it to this one; go ahead and do it. This may take a while too because you will install the applications, songs, data, etc. you had on it before.
    WARNING! DO NOT DISCONNECT YOUR IPHONE 3G WHILE SYNC IS IN PROGRESS OR ELSE YOU WILL BE STUCK IN RESTORE MODE AGAIN!
  • 3 If steps 1 and 2 did not work or you do not have another computer to sync it with the following steps will help.
  • 4 Backup your music, videos, and applications. Typically it would be the iTunes folder in the My Music folder. This is a precautionary step to the following steps to come, your music should be unaffected but stranger things have happened.
  • 5 Uninstall iTunes, Quicktime, and other Apple component software from your computer. Follow the steps listed on the Apple Support page, "Removing iTunes, QuickTime, and other software components for Windows XP" the link is available in the resources section. Restart your computer when done.
  • 6 To be sure everything is uninstalled completely run the Windows Installer CleanUp Utility. This program removes remnants of uninstalled programs from your registry and deletes files that the uninstall fail to catch. You can download and read more about this program from the Microsoft Help and Support Page, "Description of the Windows Installer CleanUp Utility" the link is available in the resources section. Restart your computer.
  • 7 If you have a registry cleanup utility like Registry Mechanic or CCleaner run the program and restart your computer. It is sad to say but the Windows Installer CleanUp Utility may not catch everything so having a secondary cleaner could be essential.
  • 8 Install the latest version of iTunes. Currently iTunes 8 is the latest, it could change tomorrow so download it from Apple.com. Restart your computer.
  • 9 Open iTunes and connect your iPhone 3G. It may take a while for it to recognize the phone, be patient. Once iTunes recognizes your phone it will prompt you to download the latest iPhone software, the current version is 2.1. Follow the installation instructions in the Apple iPhone - Software Update page, the link is available in the resources section.
  • 10 Hopefully these steps helped you recover your iPhone 3G. It is possible that even after a successful recovery your phone may revert back to being stuck. In my experience I was able to save my iPhone 3G from restore mode but when I downloaded the software update it got stuck again, luckily steps 1 and 2 fixed it.
  • Oct 06, 2010 | Apple iPhone 3G
    How do you remove synced photos from the iphone?
    You can do this in iTunes - with the iPhone connected select the 'photos' tab and deselect the folder containing the photos, then hit Sync to remove them.
    Alternatively, just move the photos to a different location on your hard drive (out of any folder that is set to sync to iPhone), then connect to iTunes and hit sync.
    Hope that helps!
    Oct 30, 2009 | Apple iPhone 3G
    I cant get the phone to sync with itunes. It is brand new 3GS 32g
    Try restoring to a previous OS. You can download them from Apple.
    Oct 16, 2009 | Apple iPhone Smartphone
    ITunes doesn't recognize iPhone SIM card
    u pls jailbroke the iphone with redsn0w , then it will be
    Aug 26, 2009 | Apple iPhone 3G Black Smartphone
    How to load itune in my iphone?
    iTunes does not load to your phone. iTunes is the program that syncs your music over to the iPhone. You have to download iTuens on to your computer, then sync the iPhone with the USB cable.
    See this link:
    Download the latest iTunes to your computer :
    http://www.apple.com/itunes/download/
    Set up iTunes syncing:
    1. Connect iPhone to your computer, and open iTunes (if it doesn’t open automatically).
    2. In iTunes, select iPhone in the sidebar.
    3. Configure the sync settings in each of the settings panes.
    4. Click Apply in the lower-right corner of the screen.
      By default, “Automatically sync when this iPhone is connected” is selected
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Jun 12, 2009 | Apple iPhone 3G
    Apple iPhone: white frozen screen - is it dead?
    Try the following to reset your iPhone:
    Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
    To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
    Thanks, Joe
    Apr 11, 2009 | Apple iPhone Smartphone
    Sync Outlook Contacts & iPhone
    When you create a new Contacts Folder you have to make sure that you create as a subfolder of the main contacts folder (in the create window you are shown the file tree).
    I had the folders moved in different groups as well but I am not sure that it made a difference.
    Please note that you have to leave outlook and itunes on for a few minutes before they synch and iTunes see the new folders.
    Oscar
    Sep 07, 2008 | Apple iPhone Smartphone
    Help me pls. i cannot put my playlist from my itunes to my iphone
    Sep 20, 2007 | Apple iPhone Smartphone
    Cell Phones Logo
    55 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
