Question about EuroTech EDC158 Electric Dryer
My EuroTech dryer turned on for a second then I heard a popping noise and it turned off. I noticed at the bottom of the dryer (right side) looking through the vent, I saw a spark. What is wrong? I do not have a service technician anywhere in my area to fix this type of dryer.
  • radams22 Sep 15, 2010
    Hi heatman 101,
    Thanks for the info. The dryer is electric and doesn't heat or spin. When I turned on, there was a spark that ran from bottom of dryer to control panel.
    Hi, Yep, a wire had worked itself loose and was rubbing against the drum. Problem solved!
    Thanks a bunch for your help!
  • EuroTech Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The electric heating element broke and is touching the metal and shorting out...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 14, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Sep 15, 2010
    That is what I originally thought...
    The heating element has shorted...pull it out and look for a broken wire...and then replace it...
    hopefully it didn't fry anything else..
    heatman101
  • D. Floyd Kolb
    D. Floyd Kolb Sep 16, 2010
    A "very helpful" 4T rating would be nice...
    Glad you found your problem!!
    heatman101
What causes a popping noise from front end, and a rubbing noise , not grinding
4wd?? Check CV shafts. Also look for whats rubbing. whre is the dirt rubbed off.
Feb 26, 2016 | 2005 GMC Yukon
Maytag neptune dryer makes loud noise on the right side when top dryer is on
The belt tensioner bushing could be shot or there may be a piece missing from the belt. Did you check the back for a removable observation cover?
Jan 05, 2014 | Maytag Neptune MCE8000AY Electric Dryer
I have a Maytag Dependable Care Plus/Heavy Duty dryer (LDE8704ACE) that has served me well with no problems for more than 16 years. Yesterday, it started making a thumping noise that sounded like a huge...
hi look at the lower bottom of front there are 2 screws pull from bottom hing out watch for door switch wires swing front around. look in side top left and right corners 2 5/16 or 3/8 bolts pull them out. lift top up you will see screws that hold fin. oh turn power off hope this helps jim
Oct 13, 2010 | Maytag PYE2300AY Electric Dryer
Eurotech dryer. ON light flashes on and off, beeps once, and still flashes then nothing happens, dryer won't start. Help?
The problem is that you stopped a cycle before the program knob reached the "STOP" (12 o'clock on the knob). All you have to do is turn on the machine, turn the knob to STOP, and wait a couple of seconds. You'll hear a tone and the ON/OFF light will stop blinking. Turn the program knob to the cycle you want and- viola! you're good to go!
May 20, 2010 | EuroTech EDC158 Electric Dryer
I am not sure if the wheel bearing on the front end is broke. it makes a loud poping noise when turning and the wheel is towed in
Loud popping/grinding most noticeably heard when turning is normally a sign of a bad CV joint. Look under the van where the axle half-shafts come out of the transaxle and connect to the backside of the wheel assembly. Are the rubber boots on the axles torn or missing?
If you hear the popping only in left turns, your right CV joint is bad, If you hear the popping only in right turns, your left CV joint is bad.
Nov 10, 2009 | 1999 Ford Windstar
Power train, transmission questions.
Get ready for a overhaul. Ask the transmission companies and they will tell you that us Dodge owners are their best customers. Your torque converter is getting toasted. You have about 10k before it goes. Sorry for the news. Got mine done and now at 213, ooo so it was worth 1700 to get it fixed. got an extra 60 k and going strong.
May 15, 2008 | 1995 Dodge Caravan
Need help
It may be the control panel board. Replace it you can probably do it yourself and that should solve the problem.
Jan 09, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Hitachi 51F500 (Two separate problems?)
My guess is that the sound you heard was that of some High Voltage discharges that could have fed back and damaged some semiconductors including the microprocessor itself. Since it could be a very expensive repair, I would be very tempted to look around for a new HDTV by JVC or Toshiba. Hitachi has slipped a notch or two in recent years according to my experience.
Jan 25, 2007 | Hitachi 51F500 51" Rear Projection...
EuroTech EDC158 Electric Dryer Logo
194 people viewed this question
Top EuroTech Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
