I got a question pertaining to the following thread ( http://www.fixya.com/support/t1808523-dell_4201c_horizontal_static_lines ). The OP said he replaced the board and it did not change the picture. Another poster ( ejb747vh ) said the same thing. What are the possible problems that could be causing this and what methods of diagnosing can we use? I have access to multimeter, oscilloscope, etc. The picture posted by the OP is very similar to my problem except the red lines seem more horizontal for me. Peter
  • sdijkk Sep 13, 2010
    The menu functions work properly. Is there a way to check these boards outputs to determine which is malfunctioning? I have access to multimeter, oscilloscope, etc. I would like very much to find the board and even down to the component(s) that are causing the problems.
  • 4,889 Answers
The only other possibility for this problem is the energy sustain circuit. There are two sustain boards x-sus and y-sus that you have to replace to get rid of this . The logic board was just one of the possibilities but it also has additional symptoms like the menu functions not working.
Posted on Sep 13, 2010
  • eagle338
    eagle338 Sep 13, 2010
    I would have loved to help you do that but the only component that is not solid state on these boards are the electrolytic caps. You can try testing their capacitance to see if the values are abnormal.
Horizontal lines samsung lcd tv, then more horizontal lines, then complete static out, TV restartes itself. after a 5 minutes or so, it seems fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 04, 2015 | Samsung Televison & Video
How to reassemble a dell dimension 4700
1) FOLLOW ANTI-STATIC PRECAUTIONS
There, did I say that loud enough? I want 'Everyone in the room to hear me'.
You body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Relieve your body of Static BEFORE working on a computer, and BEFORE touching any of those hardware parts.
(Especially new ones in an anti-static bag or carton)
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.\
Should you leave your computer in the middle of working on it, (Restroom break, lunch/dinner, etc), be SURE to Touch the metal frame again upon your return.
2) http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
3) http://www.fixya.com/support/t474552-connecting_front_panel_leads_generic
4) ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
Regards,
joecoolvette
Oct 05, 2012 | Computers & Internet
I am looking for a multi function relay similar to the Dayton (1)6A855 but with a 240vac input not 120vac input. Can you assist please. Regards Bruce Peters
1) Dayton 6A855 time delay pin timer
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+6A855&op=search&Ntt=dayton+6A855&N=0&sst=subset
Grainger owns Dayton, so you might want to contact Grainger
http://www.grainger.com/Grainger/static/help_contactus.html
1-888-361-8649
2) Time delay timers at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
3) Grainger shows time-delay 8-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN7?Pid=search
Grainger shows 11-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN6?Pid=search
Searching for "11 pin 240Volt delay timer" turned up results:
4) Following pdf shows knob-adjustable 240V delay-on pin timer
https://www.relayspec.com/specs/020050/T1Series.pdf
5) Signaline has delay timers (800) 862-2875
6) SSAC
http://www.ssac.com/standard/ff-tdr1.htm
7) Another pdf with 240V delay pin timers
http://www.askco.com/pdfs/tdd_tud_data.pdf
8) Not wanting to say what already know, but each 240V circuit is made from two out-of-phase 120V lines. Any 240Volt Load can be turned OFF by turning off one of the 120V lines. In this way, the Dayton 120V timer can be used to control 240V load.
Also the 120V Dayton can operate 120V double-pole contactor, and then the contactor controls 240V Load.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#contactor
Apr 04, 2011 | Amperite Dayton Solid State Timer On Delay...
I have a Dell 4201C-HD plasma and the picture comes out with hundreds of horizontal lines and like repeater shadows.
1. Check for bad capacitors and transistors both through mount and
surface mounted in the vertical section of your TV.
2. If no problems are found focus your attention on the tuner check
for broken connections wiggle your coax connection to see if the
problem clears also check for open inductor coils.
3 Check the vertical and horizontal output chip if they read shorted
replace
Aug 14, 2010 | Dell W4201C 42 in. Plasma HDTV
Dell 4201C Horizontal static lines
its the ss logic board. It is located behind the main board assembly. Its purpose is to send the signal to the mainboard for video clarity. The mainboard is OK, it the board below it. there is a numeric stamp on the board. Locate that number and google it or get back to me I may be able to further assist you.
Mar 16, 2009 | Dell W4201C 42 in. Plasma HDTV
Buying Dell Power Supply for 4201C Plasma
You can get it from guy at
plasmatech@gmail.com
He has everything for Dell TVs!
Nov 19, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell Plasma 4201c
There is no Dell tech site for servicing the TV, there are no user servicable componets in the TV.
If the TV is uneconomically repairable, then I'd say cut your losses and buy a replacement.
I wish I had better news but with the cost of repairs increasing and the cost of replacements dropping older TV's are quickly becoming disposable rather than repairable.
here is an example:
http://www.jr.com/panasonic/pe/PAN_TH42PX80U/
Sep 04, 2008 | Dell W4201C 42 in. Plasma HDTV
Horizontal lines in photos
Take a look at this thread (the best solution by "techman"):
http://www.fixya.com/support/t103590-white_line_across_image
It appears many vendors have had complaints and the result is a CCD (image sensor) failure when exposed to high humidity and heat.
Hope this helps...
Mar 16, 2008 | Sony Cybershot S650 Digital Camera
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
