Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
How to replace belt - Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
  • 1,040 Answers
This link: https://www.vacbelts.com/bissell-powersteamer-pro-belt-pack.htm should supply all you need.
If you need further assistance, let me know.
Thanks!
Jim
Posted on Sep 13, 2010
What is the replacement belt number?
Shop for Eureka Vacuums What is... on Google
Eureka® Replacement...
$2.89
Staples Eureka Upright Vacuum Clea...
$5.99
Eureka Eureka Hand Vac Belt
$2.49
Eureka Eureka R Type Replacement...
$5.99
Bed Bath & B...
(4) Eureka AS1104 Drive Belt
$3.49
Google Trusted StoreeVacuum... Search Results
    Belts - Eureka
    www.eureka.com/en-US/Vacuums/Accessories/Belts/
    EurekaWith high-quality vacuum cleaner belts from Eureka, you can get better performance from your ... For optimum performance replace belts every 12 months.
    Eureka Replacement Belt for Upright Vacuum ... - Walmar
Jan 19, 2016 | Eureka Vacuums
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
I need to replace the belt. Have the belt and the vacuum bottom off. What do I attach the belt too?
This unit has 2 belts. The V-belt on the brush usually doesn't cause problems. The larger flat belt requires regular replacement ( belt # 38528-035 ). The belt is first placed around the motor shaft toward the rear of the machine, and then around the large pulley. You must have strong fingers to stretch the belt over the drive pulley. Start the belt at the top of the pulley, and try to "roll " it around the pulley a little at a time, holding the belt firmly around the pulley as you go.
Feb 21, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Seems like the belt may be getting old and not picking up as much as it used to.
Belts need to be replaced periodically. If the belt is worn it will not pick up the way it should. You can get DC07 replacement belts here:
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Oct 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can the belt in the clutch be replaced or do I have to buy a new clutch and belt assembly?
You don't need to replace the whole clutch, you can replace just the belt. You can get the clutch belt and the brush roll belt combo pack for the DC07 here:
http://www.vacbelts.com/dyson-clutch-system-belt.htm
Oct 26, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
Need to replace vacuum belt
how do i change belt on morphy richards ultralight cyclone cleaner?
Jan 04, 2009 | Vacuums
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
How to replace a belt successfully on a Bissel Powrforce 3522?
How do I replace the belt? I don't know how to get into that area.
May 21, 2008 | Bissell 3522 PowerForce Bagged Upright...
1800 vacuum cleaner belt replacement
Generic problem for all Vacuums
How do you get into the belt to replace it?
Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
http://www.dooyoo.co.uk/vacuum-cleaner/typhoon-1800-upright-vacuum-cleaner/1021772/
Apr 07, 2008 | Vacuums
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
64 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
