Question about RCA Lands Phones
We have RCA executive series 4 line telephones. Is there a juction box that we can install to make this system work?
    President:
  • RCA Master
  • 860 Answers
The RCA 4 line phone uses 2 standard telehpone jacks. Line
1&2 on the first jack and lines 3&4 on the second jack.
Posted on Sep 13, 2010
Recording with a Digtal Voice Recorder
Your telephone does not contain a special connector for this type of device. Besides, I wonder if your voice-recorder has a connector for this, like a mic-in. If there is, you can consider to buy a special electronic device, which taps the audio from the telephone-line and hook it up to your digital voice recorder.
Also, you can do it without this electronic device, but requires electronic knowlegde and tools.
If the phone and the voice-recorder both miss a connector to connect to each other, you can always go for the handsfree-mode of this phone and activate the voicerecorder when there's an incomming call..
Oct 14, 2013 | RCA Executive Series 25404re3-a 4 Line...
How do I reset the message indicator light?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 18, 2012 | GE Rca 25414re3-a Executive Series 4 Lines...
Missage light blinking
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Oct 29, 2012 | RCA Executive Series 25404re3-a 4 Line...
The message is blinking but there is no new message. I have a rca executive series 25414re3a phone with 4 lines
I inherited this phone,; how do I check new messages when the message is blinking? I don't see anything that says play.
Jun 16, 2010 | RCA 25413RE3 4-Line Corded Phone
Have an RCA executive series. the light for the
I have an RCA Executive Line 4-line phone. I was away for a week, and came back to find the speakerphone when I dial out is significantly muffled on some of the lines (people that I am calling complain of noise on the line). If I take it off speaker, the quality on the handpiece is normal. First, I thought it was the batteries, so I replaced them. Didn't change. Is there a reset? Is the phone (base) after less than 1 year defective?
Sep 30, 2009 | RCA Lands Phones
How to get Caller ID
give a application in exchange to activate service
Jul 30, 2009 | RCA 25413RE3 Corded Phone
RCA Executive Series 4-line model# 25413RE3-A
I was having the same problem...no caller ID. Then I looked up the phone on the RCA site:
http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=22&idproduct=11
Turns out there is no called ID on this model =(
May 08, 2009 | RCA 25413RE3 Corded Phone
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
Mar 30, 2008 | RCA 25202RE3 Corded Phone
I have RCA Executive Serices 4 lin system Phone and I used to use headset all of sudden I hace message saying " Error: inhibited ". Would you plaese help fix my problem. Thanks for your...
Tom,
I had the "error: inhibited" problem with my RCA 4-line Executive Series phone as well.
When I checked the line from the phone to the wall outlet, I saw that it had come undone.
After I plugged the phone back into the wall, it started working normally again.
I recommend substituting in a different, known-good telephone to see if that works.
If you can't get any phone to work plugged into that extension, then the extension is dead.
If another phone works but your RCA still will not, then the problem is with the RCA phone.
A similar idea is to try moving your RCA phone, substituting it in place of a working phone.
If it works in room X but not in room Y, suspect the phone wiring running to room Y.
This phone employs a common but awkward means of wiring up lines two and four.
Line two is wired to the wall by piggybacking on the patch cable used for line one.
Line four is wired to the wall by piggybacking on the patch cable used for line three.
A phone cord has four wires running through it, but a phone signal requires just two.
The piggybacking technique leverages the cable's free pair to feed a second line.
The upshot is that one can test the wiring for lines one and three with a simple, plain phone.
To test the wiring to lines two or four, some specialized knowledge is needed.
In place of that knowledge, a different two-line phone which also piggybacks might be used.
That's detail you'll need to consider only if your problem is specific to line 2 and/or line 4.
Anyhow, I hope I'm not patronizing by being too simple. But, I had this problem too.
It turned out to have nothing to do with the phone itself; the signal wiring to it was bad.
I realize that this feedback is a bit late and that you've likely already resolved your issue.
Perhaps this feedback will someday help somebody else (since these Q&As are archived).
Regards,
Lincoln
Mar 09, 2008 | RCA 25403RE3 Corded Phone
Lands Phones Logo
252 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
