Question about Zanussi ZM24STX 900 Watts Microwave Oven
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
My 6 yr old son in a rage slammed the microwave door and in doing so broke the microwave the closing device. The male black plastic peg on the door that inserts into the main unit should lock into the white plastic retainer. However the door slamming caused this white palstic retainer to shear hence the door no longer locks into position and the unit no loner powers up. I need to replace this white plastic retainer. Do you know what the part number is and how do i remove the control panel to fit it?? Many many thanks Gary
    Guru:
  • 859 Answers
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
Posted on May 15, 2008
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
Door Switch- SCA2001 FSS 02 GE Advantium 220v
a parts diagram would be useful here..let me go see what's available
Apr 01, 2008 | GE Advantium SCA2000B Microwave Oven
E-Wave over the range microwave has blown main fuse
My Ewave has stopped heating eventho it appears to be running. Is is possible the power has been reduced or does the microwave need to be replaces
Nov 16, 2009 | Microwave Ovens
How to replace a circuit board/timer of lg refrigerator lfx25980st, remove the old and putting a new one.
Hi, I will try my best to explain this repair. The light cover inside the fresh food/top section needs to be removed. Grab the light lens on the edge farthest from the door and pull downward. There are 2 tabs that need to be released. Now you will need to use a flat blade and pry the next section off. Start from the front and work you way back. It will appear to be impossible but it will snap off.
Once you get this section free, you will need to loacte the timer board case. It is a plastic box that snaps into place. Good ole plastic right?
PLEASE make sure the refrigerator is unplugged before you replace this board.
I hope this helps you. I just changed one last week and it was frustrating mainly because I thought the plastic was gonna break.
Please let me know if my instructions helped you or if I can assist you furtether.
Vic
Jul 11, 2009 | Microwave Ovens
How do you change interior 20 w lamp?
remove the 3 screws on the vent above the door. Next unplug the oven from the power source.Next you will see a single silver screw above the control panel..remove it and slide the control panel upward and out. This will give you access to the lamp socket...turn it left or right and pull slightly ...you can now unscrew and replace the bulb....It was my exp that the lamp got loose in the socket from slamming the door after about a year, and I only had to tighten the bulb..Hope this solves the problem...Jerry
Mar 19, 2009 | Frigidaire FMV156EM Microwave Oven
Black plastic catch on door snapped off, need new part
Yes. That's the door latch.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 14, 2009 | Hotpoint RVM1435 Microwave Oven
No power
That would probably be a bad secondary interlock (bottom door switch) or its mount.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 11, 2008 | Sharp R-1480 Microwave Oven
Microwave not cooking
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
The best place to order parts is Tritronics. You can also call them at 866-779-5835
Nov 21, 2008 | Panasonic NN-T990SA Microwave Oven
Defective microwave
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 06, 2008 | Jenn-Air JMC7000 Microwave Oven
Replacing the door catch
If you're talking about a hook-like device that sticks out of the door and goes into a hole in the chassis of the microwave (or any other internal part of the door for that matter) you'll have to take the door apart. Brands and models vary, but some use screws which are obvious, and others use hidden hooks similar to the ones in the drawing I've added to this post. If you can post or e-mail photos of the area where the part goes, we may be able to translate our experience with other brands to yours.
Jan 30, 2007 | Smeg FME24X Microwave Oven
Zanussi ZM24STX 900 Watts Microwave Oven Logo
260 people viewed this question
Top Zanussi Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Zanussi Microwave Oven Expert? Answer questions, earn points and help others
