Question about Sony Cyber-shot DSC-W120 Digital Camera
When i turn it on to take a picture the len goes out and in then closes and says turn power on and off?
  • benchfyi
    benchfyi Sep 13, 2010
    did you dropped your W120?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 13, 2010
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
My ex Z1000 wont take pictures. i turn the camera on the lens goes in and out some times it looks like its going to let me take a picture and then the lens closes back into the camera and the screen goes...
your camera problem has the problem chance. Fisrt you should try with full charge battery. sometime weak battery cause also. Second main pcb does not resetting every time after taking picture. I hope you luck! Would you give more detail problem...
May 21, 2011 | Cameras
The lens won't close
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 27, 2010 | Canon PowerShot A540 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
TURN ON AND OFF
there is something in ur camara under the cage broken, very small pice, open it & take it out & close it again & it will work.
Dec 27, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
E 18 problem
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Oct 02, 2008 | Panasonic Lumix DMC-LS75 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
When i turn camera on shutter closes and lens goes inside, and other way round...
Try the Sony web site technical help. but I feel that there is a main board fault developed here- perhaps time for a new camera try the tech help first though
May 28, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Cyber-shot DSC-W120 Digital Camera Logo
512 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
