Question about NorStar T7316E Phone
Nortel meridian - it seems like it is going automatically to ext. 25, not receptionist if the phone goes unanswered after 4 rings - not sure why. Call forward/no answer programming help
  • jesse504 Sep 13, 2010
    It is not a problem with the system - I need to change the call forward no answer extension.
    **2663444 only shows a. configuration, not terminals@sets, so I cannot change it there...
    President:
  • NorStar Master
  • 860 Answers
When you say that it's not going to the receptionist, Is it when someone is allready in the voicemail and presses 0 or is it that the caller gets ext.25's mailbox instead of the main greeting?
Posted on Sep 13, 2010
    President:
  • 1,566 Answers
Have you tried resetting it back into defaults again? Or restarting the whole system? Meaning the whole PABX system.
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
Phone rings 4 times then goes to message I want it o keep ringing
Basically, you want to disable Forward No Answer to voicemail:
Feature ** CONFIG
Terminals&Sets
enter ext #
advance past Line Access to Capabilities
go to Fwd No Answer
CHANGE softkey to None
go to Fwd On Busy
Jul 01, 2014 | Nortel Lands Phones
The phones ring just 4 times before they go to message I want them to ring at least enimes
I don't know what "enimes" is, but that's the standard for those phones. I don't think it's changable unless the entire system is changed.
Jul 01, 2014 | Nortel Meridian M7208 Corded Phone
I have a Nortel Telecom Meridian phone at work. I often get unsolicited calls on my work phone and I just want to ignore them instead of answering them. How do I mute the ringer on my Meridian phone. It...
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
Sep 10, 2010 | Nortel Meridian M7208 Corded Phone
Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
Apr 13, 2009 | NorStar Meridian M7310 Phone
I have the Nortel BCM system and the problem is with a Norstar Meridian M7208 phone. This phone randomly rings (constant rings no pause between rings) and the only way to stop it is to unplug the phone...
I had that same issue before...
I turned the:
-> Autoset Relocate to On
-> then punched the set down on another port on the BCM system
I think it's just a bad port on the system...
The swap fixed my issue at my site. It was not a set problem, just something funny from the BCM.
Not too sure if you have the means to do that swap on the system yourself. But, it can be fixed.
Mar 17, 2009 | Nortel Meridian M7208 Corded Phone
My phone, a meridian M7208, does not ring incoming calls
following a power failure, the only phone that rings is the one in reception. light still flashes but no ringing from any other phones
Feb 16, 2009 | Nortel Meridian M7208 Corded Phone
My Nortel Meridian M2008 phone will not ring
it may be turned down to low.press the program key and use the scroll bar below the keypad to find your option...hopes this helps
Dec 05, 2008 | Nortel Meridian M26 Corded Phone
Help Request
Do you have any programming experience on your system ? Is seems like the line has to be asigned to the phone it is ringing on but you will have to do that in system programming.
Jul 28, 2008 | Lands Phones
Lands Phones Logo
54 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
