Question about Technics SA-DA10 Receiver
Hi, my amp keeps cuttinf off and showing the overload sign with a clicking sound.
    Genius:
  • Technics Master
  • 1,550 Answers
The audio amplifier IC´s are in short circuit need to be replaced
Posted on Sep 13, 2010
Testimonial: "Quick response, Excellent"
I have a gem sound 1000 watt amp with no sound fuses blown and keeps burning fuses
Fuses blow when there's an overload. This is generally caused by a semiconductor acting as if was a piece of wire. You should look to the devices located on the big heat sink. If they are transistors a multimeter will show it quick. For on the ohms scale test leads across the terminals of each faulty transistor will be just like you had touched the two leads together!
Aug 04, 2013 | Gem Sound Audio Players & Recorders
Signs of a blowed 15 inch subwoofer
Melted voice coil? Short circuited voice coil due to overload? does your amplifier work properly? Is the (-) properly grounded? If the SUB is in working condition and there is nothing wrong with the amplifier.
1) The amp is not powerful enough to run the sub
2) The amp is not properly grounded or powered
3) Remote Sensor wire is not connected
4) RCA Cables or Hi - input sensors are not connected
Check out the installation to verify or the sub may be damaged
Apr 25, 2013 | Tsunami Car Audio & Video
My Precision Power PCX2125 amp is just making a clicking sound win on what is wrong
Not a car amplifier man.
Do know the clicking sound is a circuit breaker. You are hearing it set, then click off.
Something is overloading the amp, or something HAS overloaded the amp.
Like somebody hooked the crossover wrong.
(Hmmm, lemme see...........Subs need 4 OHM's, and tweeter/mid-range needs 2 OHM's, and I need to bridge it how?)
Has overloaded may mean board level component repair.
You're going to need a solder jockey for that.
(Technician)
Regards,
joecoolvette
(However I wouldn't be surprised, if it's easy to replace Electrolytic Capacitors inside. Just need a little soldering expertise.
Yes, this is for desktop computer mobo's, but can apply to any electronic item that uses them,
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://www.diymobileaudio.com/forum/car-audio-classifieds/63113-fs-~-ppi-precision-power-amps-pc6600-pc2150-pcx5800-pcx4125-pcx2125-~-2.html
Scroll down if you want to see the 'Guts'.
Mar 29, 2013 | Computers & Internet
I want to install the printer on my laptop
Hi, Please follow the instructions to install it If you have a disk for your printer then put the disk in It would automatically pop up a window to install the printer (If doesn't, go to My Computer>CD/DVD drive and at the bottom most of the window, you would find an Hp Icon with the name Setup Click on setup and it would show you the installation window, Follow the instructions after you click on install, it would show you a window saying please allow all hp processes... click next on that window After that it would show you the window to Agree the terms and conditions, so please select 'I Accept and click on Next' If in between any window showsjust keep clicking Next, Until you don't get to the point which says connect the USB cable Once you would connect the Usb cable it would show up a green bar, Once it completes please click on next And then a Windows would come up saying 'Congratutalations!! Your printer has been installed completely' Click on Finish and your printer is setup If you don't have the software CD, click on the link below to download the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3645100&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Select the operating system that you are using and click on next It would show you the drivers below Click on the (+) sign next to drivers and download the Full feature softwares and drivers Once you click on download, a window would pop up asking Run or save Click on save and the window the pops up Select Desktop on that and click on save Then once its downloaded, click on the icon that shows on the desktop for downloaded software and extract it Once its extracted, It would show up the installation screen. Then you can follow the instruction written above
Oct 26, 2010 | HP OfficeJet J4580 All-In-One Laser...
Fuse keeps blowing out
Suspect an overload in either the power supply or main amp section. Chances are some kind of semi-conductor has gone gone short circuit. You might be able to spot it with either a crack or damage or signs of burning. If it is a transistor an Ohm Meter will show it up, as it will be just like you had touched the probes together, when touching two terminals with them.
May 06, 2010 | KLH ASW12-120 Subwoofer
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Gas keeps going is it worth fixing or is a new one better
I assume you mean that your screen is showing signs of stress 7 the picture quality is suffering. This would mean a replacement screen is needed & as this is very costly then it is more economical to buy a new TV instead.
Dec 01, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
I signed into yohoo e mail & told to wait 24 hrs. to use that is three days ago,still cannot get it-----
hi
go to http://www.yahoo.com
click on Mail
click on
"I can't access my account"
specify the details of your problem
or try other times to access your email they might be overloaded at that time.
Oct 09, 2009 | Yahoo Mail
Refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Aug 26, 2009 | GE Profile Stainless Bottom-Freezer...
I hear buzzing sound and a click like a switch when the compressure turns on.
Then you will need to get that fixed. Sounds to me that your start relay and start capacitor are not making good start connection and the overload is clicking out. If you don't fix this problem soon the compressor may be damaged. I need to know if your model is the MSD2756G or a different model. Let me know..Sea Breeze
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Technics SA-DA10 Receiver Logo
204 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
