Question about Cell Phones
When i take video there is a red light indicator (Flash) how can i off that
  • Cell Phones Master
  • 17,129 Answers
Normally this is used to indicate that the recording is on. there is no provision to put this off except may be in some models.
So the other option is to mask this indicator with a black mask.
Use a thick one to cover the indication..
Posted on Sep 13, 2010
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
I HAVE 4 RED RING WHEN I TURN ON MY XBOX
Solution
Mar 23, 2010 | Microsoft Xbox 360 Console
I have 3 red flashing lights on my xbox, it works when i turn it on usually but after a while it shuts down and the 3 red lights flash. this is a constant problem, any advice?
You will probably need to contact Microsoft and get a refurbished one because the 3 red rings of death usually indicates internal hardware failure. It could also indicate overheating, or a problem with the power supply, so also check that.
Feb 25, 2010 | Microsoft Xbox Console
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I have 1 red light flash on xbox 360
Hi, 1 red blinking light is an indication of an electronic failure. The E 73 is the failure code. If this unit is under warranty, call Microsoft and they will issue a return label for the repair. Good Luck to you!
Feb 22, 2009 | Microsoft Xbox 360 Console
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
When new batteries have been put in both controllers of the wii, indicator lights supposed to indecate power level of batteries instead of which all blue lights flash then stop and nothing happens, no...
If all the lights are coming on then going off again the controller needs to be synched with the wii. Once it is synchronized after all the indicator lights flash one should stay on indicating which player you are (1 -4)
To synch a controller to the wii:
Make sure the wii is in
Open the battery cover on the wiimote
Open the front panel of the wii
Press the synch button on the console
Press the red synch button on the wii mote
Should work for you.
Jul 04, 2008 | Nintendo Video Game Consoles & Games
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
