Question about Homelite ZR10926 16 Chain Saw
My saw smokes profusely while runing and seems to be getting the oil from my oil reservoir. What could be the problem.
    Brigadier General:
  • 4,088 Answers
There is no common connection point within the engine itself. A possibility that the plastic lower case which contains the two tanks in a common casting has developed a crack between the two tanks which would seem to indicate fuel in the chain oil as well. Replacement of the plastic casting seems to be the only remedy. Make sure that you are using 50:1 well-mixed fuel to oil ratio. Another unlikely possibility is a very loose crankshaft output bearing/seal assembly that could be drawing chain oil in from the chain area. Check for this by removing the bar and chain, then try moving the center of the clutch assembly in various directions. If perceptible movement is noticed, replacement of the bearing and seal would be desirable. Hope some of this helps!
Posted on Sep 14, 2010
Oil and smoke shooting from the muffler. Please help!
check the oil to see if it smells like gas if so a carb problem was it stored other than flat?
Jul 07, 2012 | Garden
Lawn mower throwing oil from muffler
If the mower has been tipped it will have sent oil up the breather and into the back of the air filter box, this will soak the paper filer and smoke badly, remove the air filter cover and filter, run the engine with these removed until the smoking stops, now replace the filter with a new one, when tipping the mower only tip it back on the handles, not from either side.
Jul 07, 2012 | Briggs & Stratton Garden
97 continental over heats . radiator fans works, we even connected fans directly to batt for cont run. drove about 90 miles with heater on,with full of water,fans runing continously, it still got very hot ...
One thing people tend to look over is the very inexpensive reservoir/overflow tank cap. These tend to lose pressure over time due to heat rotting the seal.
Jun 01, 2011 | 1997 Lincoln Continental
I just bought a Ryobi 18v cordless chain saw. Filled the oil reservoir, pumped etc and used. Left it overnight and now the contents of the reservoir are all over my garage floor. Instructions said to...
Man, I know what you mean. If I am not going to use my saw, I empty my saw oil back into
the oil bottle using a large funnel to catch it all. Then I can put the saw in a large cardboard box
lined w/layers of newspaper in an upright position til next time. Works great! Get back to me if
you need help sharpening that puppie...............dansky66
Mar 26, 2011 | Ryobi Factory Reconditioned 10-Inch 18...
No oil seems to be getting to the chain
There is a blockage from the oil reservoir to the chain.
Jul 30, 2010 | Garden
White smoke from the engine
Give it some time, probably cleaning out some residual from somewhere.....if it returns consult the people who worked on it...Keep all fluids topped up....if you had blown gasket your oil would be a milky brown...Good luck to you friend...Tim
May 13, 2009 | 2006 Aprilia Atlantic 250
What kind of oil do I use in the oil reservoir of my chain saw?
I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
Apr 26, 2009 | Remington 16" Electric Chain Saw
Homelite ZR10926 16 Chain Saw Logo
97 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
