Question about Audio Technica AT-PL120 Turntable
How do you replace the tone arm rest (plastic holder/lock) on a Audio Technica AT-PL120
  • Brian Halliday
    Brian Halliday Jan 01, 2015
    AT-LP120 Tone Arm Lock Replacement Procedure Required tool: Phillips head screw driver #00 with a 3 inch shaft 1. Remove the plastic dust cover. 2. Remove the tone arm counterweight. 3. Remove the head shell with cartridge. 4. Move the tone arm to the center of the platter. 5. Insert the Phillips head screw driver under the tone arm mounting bridge and under the tone arm itself and engage the tone arm lock clamp screw. 6. Remove the screw and the old clamp. 7. Mount the new locking clamp. DO NOT OVER-TIGHTEN THE Phillips screw or the clamping lock will bind. 8. Replace the head shell counterweight and dust cover.
    Champion:
  • Audio Technica Expert
  • 271 Answers
Hi, there is a screw that fits up underneath the clip that needs to be undone to remove the tonearm rest clip. styluscity@gmail.com
Posted on Sep 13, 2010
Testimonial: "Good stuff. We'll give it a go. Later....got it thanks"
Where can I purchase a replace tonearm locking clip for an Audio Technica AT-PL120?
Audio technica will send you a replacement clip free of charge. Just send their service department an email asking for one.
Feb 21, 2012 | Audio Technica AT-PL120 Turntable
My brand new audio-technica AT-LP60 turntable has skipped on every single record I've played in it (even brand new ones). Always happens at the same spot - towards the end of the record, halfway...
hi,
Do one thing adjust counterweight on the back of the arm to 1.5gm or 2gm by rotating the counterweight. It will give some more pressuer on the styles and will avoid the jerking
ok
Aug 04, 2011 | Audio Technica AT-PL120 Turntable
I'm trying to figure out what type of cartridge the ATP-2 is which came with my Audio Technica AT-PL120 Turntable. Is it "Moving Magnet" or "Moving Coil" or something else?
These are the specs for your cartridge - it is of the moving magnet variety. Vector-Aligned Dual Magnet design and A-T's exclusive Paratoroidal signal generator. This unique signal-generating system is composed of a unified, laminated coil core wound with a single piece of wire. Internal mechanical and electrical connections are eliminated, minimizing magnetic losses and assuring better signal transfer. PCOCC wire
Cartridge Specifications (ATP-2)
Frequency Response 15-22,000 Hz
Channel Separation 23/17 (dB at 1 kHz/10 kHz)
Vertical Tracking Force 3.0 - 5.0 grams
Stylus Construction Bonded round shank
Output 5.3 mV at 1 kHz, 5 cm/sec
Channel Balance 1.5 dB
Stylus Shape 0.4 x 0.7 mil elliptical
Cantilever Alloy tube
Jun 14, 2011 | Audio Technica AT-PL120 Turntable
I just purchased the AT-LP120-USB - it's was a beast to get the thing balanced correctly, but now i hear some very obvious crackling sounds that weren't there before when the tone arm wasn't...
as long as you have balanced your tonearm correctly, maybe its simply just a problem with your vinyl? could just be dust in the grooves or could be static build up, try cleaning your vinyl with an antistatic cloth to see if the sound improves.
May 05, 2011 | Audio Technica AT-PL120 Turntable
Broken ear pad holder,need a replacement
i have this same problem. I sent them to someone on ebay to get fixed and the earpad holder broke again. I don't know why audio technica doesn't just sell the part.
Jan 21, 2011 | Audio Technica Audio-Technica QuietPoint...
I just set up my audio technica AT-PL120 for the first time, and I can't stop the tonearm from drifting back to the rest. I can't get the stylus to stay straight unless I add more on to the counterweight,...
KEEP THE ANTI SKATE AT 0 FOR NOW,then you need 2 balance the tonearm with the rear counterweight so it just hovers at around the height of the platter.now you need to zero the gauge on the rear counterweight being carefull not to turn the counterweight,then check again that the tonearm still hovers.then screw counterweight inwards untill the dial on counterweight reads between 1.5- 2 grams dependin on tracking weight of cartridge.then adjust antiskate 2 whatever u set the tracking weight to.i would also double check with a spirit level ur level surface
Oct 12, 2010 | Audio Technica AT-PL120 Turntable
Brand new audio technica at-pl120 turntable not powering on; cant get turntable to spin
HELLO!
I don't know which country you are from, but if the mains plug has a fuse in it then replace it with the same type. If that does not do the trick take it back back where you bought it and get a refund or a replacement! There may well be an INTERNAL fuse inside the unit on the power supply unit which may be at fault. If it is under warranty don't open the turntable yourself - take it back - I WOULD!
All the best!
Jul 12, 2009 | Audio Technica AT-PL120 Turntable
Audio-technica atp-2 cartridge with a atp-n2 stylus
Make sure the cart is connected properly, and check the manufacter's instruction with that cart. sometimes tonearm height and weights need to be adjusted for proper torque and sound.
Oct 26, 2007 | Audio Technica AT-PL120 Turntable
Audio Technica AT-PL120 Turntable Logo
1,128 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
