Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Can i get my hard drive repaired - Seagate Barracuda 7200.10 500 GB SATA Hard Drive
No it will not repaired but u can take data out
Posted on Sep 13, 2010
Hard disk is not running frm last boot
hi,
- This means that your operating system may have collapsed and needs repair.
- To repair, enslave your hard drive to another machine by:
- Make sure the second computer has a good operating system.
- Remove the hard disk from your computer.
- Remove CD/DVD Rom from the second computer and fix your hard disk on
that drive.
- Start the computer.It will display that you're running on two drives.[Unix]
- Press F1 to save changes and continue.
- The machine notes one drive needs repair and starts the repair process.
- After it has completed and opened your system, turn it off and remove the
hard disk.
- Fix it on the first machine and start it.
- If this fails,you may need to format the hard disk.
GOOD LUCK!
Sep 11, 2011 | Maxtor (6L250S0-20PK) (6L250S020PK) 250 GB...
Hi, yesterday my hitachi external hard drive is fallen to the floor and after that it is doesn't work. but the lights are working. i want know can i take my old data from hard disk and can it...
Dropping hard drives is a sure way of damaging the drive. There is no way us mortals can repair a damaged hard drive that has been dropped.
Retrieving data fromdamaged hard disk is possible. There are companies that can remove the diskplatters from the damaged hard drive and with special equipment may beable to recover your data, but it will cost you an arm and a leg for theirservices. The reason for this high cost, they dismantle and remove the plattersin the hard drive in a clean room environment and set up the platters up injig/drive to retrieve/copy the data.
Jul 04, 2011 | Hitachi Computers & Internet
How to open my verbatim hard drive for repair
There is no concept of open hard drive and repair. Miniture dust paricles would contaminate the disks, get caught by the read write heads and distroy the unit. Hard drives are replaced, not fixed.
Oct 09, 2010 | Computers & Internet
Head for my 1000 gb hard drive
Hi.
Hard drive heads are not sold as spares. You also cannot do the job at home. Hard drives are built and repaired in vacuum environment, using a facility called clean room.
You cannot repair an hard drive head or internal motor at home, the result will be a not working or completely unreliable device.
Service to repair an hard drive head in clean room starts at no less than $800.
Aug 13, 2010 | Computers & Internet
Labtop does not reconize any hard drive
This is caused by partition table damaged, hard drive can not find system guide file and boot, you need repair it.
Repair Damaged Partition Table
Jun 01, 2010 | Gateway (M520HD80G) Hard Drive
Tools requirements for starting L3 Level Repair centre for HDD
Repairing hard drives?? you cant repair surface problems on hard drives. you may be able to repair/replace the circuit board which controls the hard drive but this is a fairly uncommon problem. For data recovery off damaged hard drives you need a very expensive clean room and very very expensive tools.
Jun 09, 2009 | Compaq Presario 5000 PC Desktop
Hard drive
Hello hubert lee,
Generally there is only one of two ways to resolve this. Depending on the severity of the corruption.
1) If the hard drive can not be repairable - purchase another hard drive and if possible install the operating system and re-install all the software programs onto your new hard drive. The corrupted hard drive, depending if you have important data to recover, you may want to take it to a local pc repair shop and see if they can recover your data.
2) See if the hard drive is repairable - you can download a gateway scan (GWScan5.12) from theere website and follow the simple instructions to copy the file onto a floppy diskette (will need to do this on another pc). Then run the GWScan, go thru an extensive hard drive test and wait for a result. At some cases, it may be able to repair your hard drive (again, depending on the severity of corruption). The following is the link to download the GWScan5.12 http://support.gateway.com/support/drivers/getFile.asp?id=21280&dscr=GWSCAN%205.12&uid=20276003
Good luck and thank you
Jul 20, 2008 | Gateway GT5654 Desktop PC
Repair dead hard drive
dont go with repairing hard drive because if it gets repaired also you can not depen on it ,because it may crash at any time and data is always important.so go with replacing the hard drive
if you want to recover something from your hard drive go with recovery software............
Good Luck.
Please let me know your feed-back.
Thanks
dilip bagdi
Technical Associate
Apr 29, 2008 | Computers & Internet
Seagate hard drive , samsung hard drive
Most ACTUAL hard drive failures are fall into one of three categories: ? Read/write head failure ? On-board electronics failure ? Damaged or worn disk platter. If your hard drive was working then you experienced a hard drive error your only real chance of ?repair? is to format the drive from scratch and run chkdisk (or similar program) on it to identify and block out any bad areas on the hard drive platters. In the case of a physically damaged board some people have had some success swapping an IDENTICLE board from another working hard drive. Since you ruin a drive (unless its dead as well) to fix another that is only something you do to recover data, not fix the drive. The bad news is no home user has the skills, tools or clean room environment to successfully replace the heads or platters in a hard drive, assuming you could buy them. Typically posts that give bad news are marked poorly and the only reason I?m posting this is to try to save you some aggravation and time so be kind 
Jul 17, 2007 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
29 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
