Question about Insignia Pilot MP3 Player
Battery is bad. Are they replaceable? - Insignia Pilot MP3 Player
    Genius:
  • Insignia Master
  • 1,550 Answers
Yes with another with the same capacity
Posted on Sep 13, 2010
Battery won't charge
try different power supply first then go to ebay and look for inexpensive replacement.
May be the internal aspect of the battery charging system. Some batteries die from bad cells or some die from bad circuitry inside battery. Sometimes the computers circuitry goes bad but everything else is fine. probably bad power supply, or bad battery.
Feb 12, 2014 | Apple Computers & Internet
Vx510le bad rtc chip how to reboot Problem
Bad RTC suggests a bad Real-Time-Clock, and it's usually bad because the battery for that clock has been let run down, or humidity killed that battery. Try replacing the battery first, then consider replacing the chip (using a soldering iron and replacement chip.)
May 31, 2011 | Computers & Internet
Not charging
Check the following to fix your problem
  • Loose battery connection.
  • Bad battery.
  • Bad charger.
  • Bad phone.
  • Bad connection somewhere.
Best solution: Remove your battery, clean the contacts and reinstall. If the battery is bad, replace it. If the charger is bad, replace it.
If these things don't solve your problem you are left with replacing the phone.
Thank you !
Jun 04, 2010 | Nokia 1100
Nokia 3110 charger not supported
  • Bad battery.
  • Bad charger.
  • Bad phone.
Thank you !
May 25, 2010 | Nokia 3110 Cellular Phone
Cant charge
  • Bad battery.
  • Bad charger.
  • Bad phone.
Thank you !
May 19, 2010 | Nokia 6300 Cellular Phone
Nokia 1208 Not charging Problem
Bad battery.
Bad charger.
Bad phone.
Best solution: remove your battery, clean the contacts and reinstall. If the battery is bad, replace it. If the charger is bad, replace it.
Aug 28, 2009 | Nokia 3110 Cellular Phone
My battery will not charge
Hello Following issue could be possible
Issue:Main computer battery does not charge.
Cause:This issue can be caused by any of the below possibilities.
  1. Computer AC / DC cable is bad not allowing the computer battery to charge.
  2. Battery is bad.
  3. Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Aug 18, 2009 | Computers & Internet
NOKIA 1208
might be Loose battery connection.
Bad battery.
Bad charger.
Bad phone.
So remove your battery, clean the contacts and reinstall. If the battery is bad, replace it. If the charger is bad, replace it.
Oct 18, 2008 | Nokia 6680 Cellular Phone
Insignia Pilot MP3 Player Logo
62 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
