Question about Toshiba 26LV47 26 in. LCD TV/DVD Combo
No picture but good sounds,with humming sound ,like motor boat even the volume is in minimum and with retrace
4 Suggested Answers
bernardlunda
  • 318 Answers
SOURCE: Humming sound from TV
take your tv to a technian and ask him to check the power supply filter.
some of the ac ripple are passing through to the main amplifier.
a filter comsist of ( semi comductor, inductops and capacitors.
Posted on Jan 03, 2010
anandsharad
  • 137 Answers
SOURCE: no sound at all. all
Bad News boy, Since you already checked the drivers and teh volume option. which makes it eaasy for us to identify the root cause of the problem.
So try these steps.
1. Check in sound and audio device properties in control pannel, if you have the correct audio device listed. also check if nothing is on mute in volume control.
2. if its not the correct one. i suggest remove the existing driver from add and remove program and then try reinstalling it.
3. If thats the correct one, then Check if the external speakers / head phones produce sound.
4. if yes, then everything is fine in the computer, Don not do anything as all the software is fine.
5. If no, then the internal speakers have gone bad, which is ver rare, but it may happen.
Consider replacing the internal speakers,
I am sure this will help you.
Best of Luck!
Please rate this solution, if you find it helpful. :)
Thanks.
Posted on Aug 20, 2010
gopakumarg43
  • 75157 Answers
SOURCE: no sound on toshiba 36 tube TV
Check its speaker/s. If it is OK, the audio output IC should be checked.
Posted on Jul 15, 2012
My boat motor Johnson 90 hp will not rev up throttle is wide open have checked coils fuel pump new spark plugs. all good boat sank a few years back. before that ran great.it is a 1986 unit
it sank..ooopppsss...sounds like trouble.. First thing I would do is check the compression with a gauge... This will require a GREAT friend.. remove all the spark plugs - makes PULLING the engine over easier.. get a compression gauge (or take it to a competent professional to get the compression checked!). Install the compression gauge... Put the throttle wide open... have your buddy yank with ALL his heart about 6-8 times..it should show about 115psi+ minimum..all 3 cylinders should be with 10+-psi.
If they are not at these specs minimum..you have found the issue..then try putting a little outboard oil into all three cylinders and repeat the test.. if the PSI goes way up.. you have found the issue.
Jun 11, 2017 | Johnson Boating
How do i get the sound back on my laptop please help me
Is the speaker on "MUTE" or volume to minimum it is also possible that WAVE is at minimum. Go to the bottom right on the desktop and find picture of a speaker, right click on in and chose open volume control and check if there are any MUTE or volume at minimum
Nov 14, 2010 | Computers & Internet
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Buzzing/humming sound from rear of TV unaffected by volume settin
Hi.
I think you have problem with the main digital PWB
You need change that part.
Nov 18, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Loud humming noise
this problem is sif coil & sound releted 5.5 crustal &releted pf try this
Jun 21, 2008 | Sanyo DS19330 19" TV
I have a Denon AVC 3030. In pro logic mode it makes a rumbling through my right and left speakers. During quiet parts of movies it is quite annoying. I know it's old but I really like it.
If what you mean is a low humming sound when the volume is turned down to minimum level, this is usually from power supply filtering problems. Most of the time this is from the electrolytic filter capacitors going out of spec with age and use, and or voltage retulation problems.
If the sound is quiet with the volume turned down, and the hum or buzz increases with the increase of the volume control, this is usualy due to a ground loop problem between the associated equipment connected to the amplifier, or a bad interconnect cable.
Jerry G.
Apr 26, 2008 | Audio Players & Recorders
Miller & Kreisel Subwoofer 60Hz hum
This is a common problem.  The potentiometer is damaged and needs to be replaced.  Potentiometer is a fancy name for volume knob.  It's a $5.00 fix if you know what you're doing.
Dec 01, 2007 | Audio Players & Recorders
Circuit board was damaged in electrical storm. Replaced with new board. Now, screen comes on full raster, but with retrace lines. Picture is very faded and barely visible behind lines. Sound is OK and...
I am unable to find in your statement about which brand or type of motherboard is used. One thing i come to know your using service mode kit. knowing in your statement your are a technical person. My simple idea is first you set the TV in standby mode using remote. Then in FBT reduce the screen control minimum position, the release standby. Now the tv is oscillated, now slightly increase screen control till get maximum video and zero retrace line set in position. Even no improvement give me clear picture of brand and microprocessor ic etc. there is a chances to solve by having the above details.
Aug 27, 2006 | Sanyo DS31520 31" TV
Toshiba 26LV47 26 in. LCD TV/DVD Combo Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
