Question about Dynex Radio Communications
When I try to use the headset, I get a message that Windows does not recognize it and so it doesn't work.
    President:
  • 1,566 Answers
What is the model of your Dynex Headset? Please try to plug it into another USB port. Also, as part of the troubleshooting, try to use it into another computer. If it works, please take note of the operating system version.
Try to download also the driver from the manufacturer's website. Make sure though that you select the correct operating system to avoid conflicts.
Posted on Sep 13, 2010
Testimonial: "Thanks! I needed to update the driver."
My Plantronics C420-M is not recognized
How To Fix Error Code 43 Windows has stopped this device because it has...
If Windows Device Manager is giving a code 43, this means the hardware is reporting something wrong when trying to connect. I'd do the following (and also check the attatched link for reference ;-) )
  • Unplugging the headset, restarting the computer, then plugging the headset back in.
  • Make sure the USB connector on your headset (and the USB port you're putting it in) is undamaged, and not dirty.
  • Try connecting the headset to another USB port, and another computer to see if you're able to reproduce the issue there (if not- it may just be the USB port(s) on your computer that you're plugging the headset into that's failing.
If all else fails, it may be time to purchase a new headset ;-)
Jan 22, 2014 | Plantronics Blackwire C420-M Headset
Unknown unit
My suggestions would be to try a different USB port. If that does not work, uninstall the drivers for the headset and then reinstall them. Sometimes driver files become corrupt and the products that use them won't be recognized. I hope this helps. If it doesn't, please let me know and I will attempt to troubleshoot further.
Mar 30, 2010 | Logitech ClearChat Pro USB Headset
My computer doesn´t recognize the headset. It is possible that this headset can´t be paired with two devices (e.g. a phone and a computer) at the same time?
If your using a bluetooth to connect both im pretty sure there will be a static interfearence and neither may work. Try just using the mic. Please make sure you have installed any software it may need or has come with. Also please look at the Support page at motorola's website and make sure you have properly installed it.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 09, 2010 | Motorola Mobility H375 Bluetooth Headset
Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
Jan 28, 2010 | Altec Lansing BackBeat Plus Mobile ...
Plantonics 220 headset is paired and recognized by my ps3 but when trying to play game it doesnt work
Maybe I can help.
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Dec 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Motorolla headset h700 pair with blackbery
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 06, 2009 | Motorola Mobility H700 Wireless Headset
USB Device Not Recognized...
Your headset is faulty. Open it to check for loose wires.
May 28, 2009 | Logitech ClearChat Pro USB Headset
The main reason for getting this message is that the USB chip or part of the connection to the chip has failed. The best way to test to see if the product is defective is to try it on another computer.
This will tell you if the product or the computer port has failed.
Sep 14, 2008 | Logitech ClearChat Pro USB Headset
Headset compatability
99% this message coming because the headset u are using is not compatible with this phone, try to go to any accessories shop try their two three kinds of headsets i am sure u will be able to get right one
Jan 29, 2008 | Nokia 2610 Cellular Phone
Radio Communications Logo
461 people viewed this question
Top Dynex Radio Communications Experts
eradiostore
eradiostore
Are you a Dynex Radio Communication Expert? Answer questions, earn points and help others
