Error Code: E000194-0115-05 Called for service, even the rep didn't know this one. Any help put there? Thanks
2 Suggested Answers
  • 2072 Answers
SOURCE: we are having a error code 09.038.46:13190 --> does anybody know what it is?
The black ink sticks are not advancing down into the ink loader properly; Either one is cracked or twisted.
If you have to remove one, use a screw, like a dry wall screw and twist it into the block and back it out.
Posted on Sep 20, 2008
I have an error code C5370, which will not clear. The Service rep is stumped at this point. Originally, we had a glob of toner that gummed up the works, and he took the entire machine apart to find t
See the link below: looks like a cooling fan error code and the fan needs repalcement. You got a GOOD REP oh yeah...
http://www.copytechnet.com/forums/konica-minolta/27391-bizhub-c253-error-c-5370-a.html
Sep 29, 2014 | Konica Minolta Bizhub C253 Copier
Baby locked my tv I didn't even know it had a lock feature
Consult the owner manual and if do not have it GOOGLE the model number of the set with "manual" to try to locate one for free.
Other option is call whoever the maker is and have the customer service rep step you thru the process to reset/unlock the feature.
Apr 05, 2012 | Televison & Video
When i turn my phone on it says input NP code, I have went to the store I bought it from they have never heard of such code I called cincinnati bell they said call motorola i called motorola they said call...
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Jun 01, 2011 | Cell Phones
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Direct tv remote code for Sylvania LC320SLX
Get the Direct TV RC65 and program in code 11864. It works I just programmed my LC320SLX.
Dec 19, 2009 | Sylvania LC320SLX 32 in. LCD TV
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
The error code is now cleared.
Hope this helps!
WizardRepair
Jul 17, 2009 | Ricoh CL4000DN Laser Printer
F1 Error Code On Whirlpool Cabrio
Hiding within your washer should be a secret coded booklet that has all the error codes that don't appear in the user's manual.
F1 generally means the Central Electrical Control Unit (as in cars, etc) it is the onboard computer. It usually inicates a fatality.
If you do not have the skill & tools to test the guts of this computer, you're stuck replacing the CECU.
BUT if you have the skill & tools then there are three screws at the rear to expose the control panel, then unplug one unit; plug in the new one. Just to be on the safe side, color code all the plugs and replace.
The Unit is normally around $200 to replace, BUT aren't you still under warranty????
If so get Whirlpool to check it out and Replace it, lol.
cheers,
Bastian
Jun 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
E3 error code on danby dhcc6020, its new out of box. tried danby service rep. , cant get a response back from them. any ideas on how to fix?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I had called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Danby Service Rep. helped me with my question about my P1 code (for DDR657EE).
Apr 11, 2009 | Danby DHCC6020 Dehumidifier
Xerox 5855C Copier
it need to replace the connector in the toner cartridge
Dec 11, 2008 | Xerox 5855C Copier
217 people viewed this question
k24674
