Question about Panasonic Lands Phones
How do i get the last caller number - Panasonic Lands Phones
My phone was showing caller ID but last evening it only showed incoming call. How do I get my caller ID to work? IT is working on my cord phone?
Hi
I would advise you to go through the instructions in the manual again very carefully to make sure you set it correctly, and then test it using a known number.
Caller ID is not infallible and will not display a number if the caller uses "number withheld" or in many cases if it is an overseas call.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Lands Phones
Callers can't call did numbers
Sounds like trouble with the call piloit
Apr 02, 2014 | Lucent Merlin Legend MLX-10DP Phone
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
The caller id is working but how to look back the last caller id number(or caller id log) on the KX-T7731, i am using it with the KX-TA824 system.
System pool is 300 numbers, personal is 20. There are logging and overwrite options in Maintenance programming 9.3 or system program 737 and 738. Then you program buttons for CID-Select and CID-Indication for either personal, system or both. (2 buttons per feature).
Carl
Sep 08, 2011 | Panasonic KX-T7731 Corded Phone
How do you get the number of a previous call? I cannot figure that out. For example. Call comes in. Phone chat. THEN, afterwards, wanting to retrieve the number of person who called. Thank you very,...
You need to enable caller id in order to see the numbers of the people who are calling you. Caller id costs about $6.50 per month depending on which phone company you use. When you have it activated, and you want to see the number of the last person who called you press the down button on the dial in the center of your phone and it shows the last one. If you continue pressing the down button you can see all callers as long as they have not blocked their numbers.
Aug 16, 2011 | Uniden DECT 6.0 Cordless Telephone...
NEED TO RECALL A MISSED CALLER PHONE NUMBER
If it was the last caller, you can dial *69 to call them back. If it's a cell phone, you can press the dial button twice and that will usually call the last person you were in contact with.
This is of course assuming that they didn't have their number blocked, if they did, there's nothing you can do without a warrant.
May 19, 2011 | Computers & Internet
I have three handsets and two of the phones caller id is not show
yes if its fading out .its possible that the battery is causing this.also other possibility is that the internal cicuit of the device is moistened or may be needs to be resoldered as some connections may be loosened up too. its a common problem and will get fixed once above things are checked 1 by 1. thanks.
Jul 08, 2009 | Uniden Cordless Phone
External caller ID does not display on either line talkswitch 284
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Jun 18, 2009 | TalkSwitch CT.TS001.124001.US...
Memory
The phone can store upto 10 24 digit numbers with 15 character names this memory is in addition to the caller id memory which stores the last 40 caller id numbers.
Apr 03, 2009 | GE 25952EE1 Cordless Phone
Caller ID
battery weak change ur battery
Sep 23, 2008 | Astra Meridian 9417 Corded Phone
Lands Phones Logo
400 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
