Question about Kenmore HE3T Washer
My HE3t washing machine is showing the F06 error. Is there any way to tell for sure if it is the motor ar the MCU?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
I have a kenmore he3t quiet pak4 front load washer. First of dhl code. I ordered a new door lock and put that in. Then I got a f06 code. Put back in old lock and still only get f06 code. The other...
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its either a faulty MCU, or faulty drive motor.
Nov 03, 2014 | Washing Machines
Error code F06 and E01
Here is what the F06 code stands for
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Dec 14, 2013 | Whirlpool Duet Steam WFW95HEXW
F06
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool Washing Machines
I have this written in my machine F06 what is that meanning
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool AWM8143 Front Load Washer
My kenmore is showing an f 06 code
F06 is a communication error between the central control circuit board and the motor control circuit board, Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its like a faulty CCU, check your owners manual, some are covered under warranty for up to 5 yrs.
Jun 19, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machine is giving me an error message F06, what does that mean?
F06 is Drive Motor Tachometer Error.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU) .
• Check the Drive Motor .
• Check the MCU .
• Check the Wire Harness .
Please read the below link it is an article about this error from one of the senior and best expert here
http://www.fixya.com/support/t2946429-kenmore_elite_he3t_giving_code_f_06
COURTESY:JSROCK
Mar 21, 2010 | Whirlpool Washing Machines
Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Washing Machines
My kenmore Elite HE3t Giving a code F 06
"F06" is a Motor Speed error code. This is an indication that there is a problem with the Drive Motor, Tachometer, Motor Control Unit (MCU), Central Control Unit (CCU) and/or interconnecting wiring between the all these components. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by checking all the connector plugs between the CCU, MCU and Drive Motor to ensure none of them are loose or have corroded contacts.
Read through the link and follow the steps provided. If you have questions, please let me know. I hope this helps.
NOTE: The majority of the time this failure is attributed to a bad tachometer which is located on the MCU. If defective, the MCU must be replaced. There is a technical data sheet that comes with the washer. It is located inside the washer behind the lower toe panel directly below the door. The panel comes off by removing the screws located under bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. If the tech sheet is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. Included are all the diagnostics and troubleshooting advice for your washer, including diagrams to show test points. HINT: For better access to the screws you can prop the two front feet of the washer up using a 2 x 4.
Sep 14, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool washing machine really loud
hi there,
error f06 means Drive Motor Tachometer Error
for this u may
  • Check the MCU
Dec 10, 2008 | Whirlpool AWM6100 Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3T Washer Logo
260 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
