Question about 2wire 1000-200004-000 Network Adapter
Remote Network Question
I have a stand alone pc. I dont' remember ever installing anything that looks like this item but I am getting this same "found new hardware message" that all these guys are getting. Is it possible that this item can be used as hardware within a network to link a stand alone pc with appropriate drivers & internet connection to a remote network? Please advise... Thanks - MKA
  • 86 Answers
Some for your hardware need software, kindly check with hardware properties,configuration
Mycomputer -----right click-----properties-----hardware----check all the drives are compactable , without any question mark,
Posted on May 18, 2008
Gateway LT2802u reset password. Do not remember password and cannot get passed the login. This laptop does not have CD drive. HELP
you can pick up a usb multidrive cd/dvd rom write/rewrite cd and dvd for 25 bucks at major computer /office supply stores. LG makes a slimline portable super multi drive for 27.00 and that was a year ago so thats would be your best bet with a stand alone computer. if its in a network restore it via ethernet
Sep 30, 2013 | Gateway Lt2802u Laptop/notebook
Medion akoya notebook
Yellow mark stands for no/ improper drivers installed for those devices, check drivers for your system model and install.
Nov 08, 2012 | Medion Computers & Internet
Hello Steffen, We have a 8830 scanner Synergix.
Hey Panos,
What are you trying to feed a paper roll or single sheets or are you telling me you cant feed the original to be scanned? Can you copy or print internal status pages from your Xerox?
But it sounds like thats not the problem as it isnt hooked up and your lappy as it dont have a serial port you only have USB...... but this is a network printer.... do you have a network or it is just a stand alone lappy?
So I guess.. stand alone lappy to Xerox.... you will need to network it... and if it just a stand alone lappy ie no network then you will need a non standard network cable called a crossover cable to go from scanner to lappy but you will also need to set up a network with them manually asigning IP's of each to be on the same network, then hooking with a crossover (normally red never blue) network cable, and you will also need the software installed on this lappy no matter which way we go
Spose you could try a serial to usb adaptor but they will have issues propally when trying to use that sort of interface on scanning, normally one has the print server that is an option on your scanner to interface with the likes of a laapy, so I dont think it would workor a good idea to go with an adaptor
Well come back with some more info because the more info you can give me about your problem the better i can understand it.. cheers
We are talking about one of these beastys.. User Manual
Cheers
Steve
Dec 16, 2011 | Xerox 8830 Copier
Not sure which port I should connect my printer to on my Dell hardrive
if it is a stand alone install for one pc, the USB port (any USB Port ) will be ok, just remember to install the cd before you plug the printer in, the install should tell you when to plug the pinter in. good luck and i hope this helps
Feb 09, 2011 | HP Color LaserJet 2600n Printer
I cant remember my password and i dont have a reset disk for a compaq presario F572US
download a bios password cracker eraser if its on startup. if its your windows password than download a stand alone windows password cleaner
Dec 01, 2009 | Compaq Presario Notebook
I want 2 configure a DVR from remote place and not from the intranet. kindly help me out in solving the issue
To configure the DVR from a remote location you can do it one of two ways:
Create a vpn connection through your router if it supports it or an external units to the remote location. This will make the remote location appear to be local to the dvr.
You can also setup the dvr's internal IP and port on your router through port forwarding. This way certain network access or traffic will be passed directly to the dvr from outside your local network.
Nov 12, 2009 | Dome 4 CCD CCTV Camera Surveillance...
I dubbed home movies from VHS to DVD but I can't get it to finalize
On PC or stand alone DVD burner?
On PC tell burning application to finalize because you most probably are burning multi-session DVD's now and not all DVD players old type accept unfinalized discs.
On standalone: go with remote to menu item where to finalize that multisession DVD (these units always make default because of design multi-session discs)
Apr 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Printer doesnt print
Make sure the printer is a network printer. Then make sure the network cable is plugged into the printer and the switch box for all the network computers. If your printer is attached to a computer on the network, then that computer works like the server. The computer has to be on for anyone to access it. Make sure you can see the other computer on you network. Then you have to set the printer up on each of the computers. Make sure you you have your installation software.
If this helps you, please rate me. Thanks, Patty
Dec 28, 2007 | Office Equipment & Supplies
Freecom 400gb Drive
Have you tried to connect those drive individually and checked if they get detected when stand-alone? If they get detected stand-alone, install the Freedom software happen. Cheers
May 23, 2007 | Freecom (24358) 160 GB Network Hard Drive
2wire 1000-200004-000 Network Adapter Logo
49 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
