Question about Canon MX700 Office All-In-One InkJet Printer
Canon mx700 printer. vertical lines print 'jagged'.
5 Suggested Answers
SOURCE: printer vertical lines
Looks like mark on drum.. Change the toner cartrige .. If the printer is older, could be that the exit rollers are worn out..
Posted on Nov 17, 2007
IB4G2008
  • 3587 Answers
SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
Posted on Feb 15, 2008
Fixe_You
  • 1800 Answers
SOURCE: Canon MX700 network problems
do u ve the copatible driver with win vista
Posted on Sep 04, 2008
pineworks
  • 4041 Answers
SOURCE: Can not print to my Canon MX700 printer. Error
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
How to solve the error 5b00 for mx700?
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Oct 05, 2010 | Canon MX700 Office All-In-One InkJet...
My MX700 printer tries to send faxes instead of printing page(s).
hi
change your default printer your mx700
1 - start menu
2 - printer and faxes
3 - right click on your printer
not on your fax icon
Jun 09, 2010 | Canon MX700 Office All-In-One InkJet...
Print to Canon MX700 via wireless print server (no network)
If you know the ip address of your printer, you can add that manually from add printer wizard copy first driver to your local drive.
Mar 23, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 printer - vertical lines aren't straight
Have you tried to do an alignment. Also check encoder strip
Aug 19, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Images and some text (especially larger text) is not lined up correctly. it seems to be printing in horrizontal bands that dont match up vertically.
That happens when the strip behind the carriage gets grease or ink on it. If you lay a print at the exit face up, you can look at the strip exactly above where the defect is, and you will see the grease spot or ink. It can be cleaned with a q-tip and water.
Aug 07, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon Pixma iP90 - Jagged text and lines
The printer has a plastic band that runs from one side to the other. The print head has a sensor that passes over it each time it moves. The band is a little transparent and appears to have vertical lines in it. That needs to be cleaned.
  1. Remove power from the printer,
  2. Wipe it clean,
  3. Move the head manually to other side to clean the other areas.
Hope this helps.
Jun 02, 2009 | Canon PIXMA iP90 Mobile Printer
Canon pixma mx700 print default
In your print dialogue box should be a setting to tell printer to print black only
Apr 23, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I am getting white horizontal lines through my color photos when I print them. Is there an adjustment that I need to make in order to eliminate these lines for a clear sharp color photograph?
see owners manual PIXMA MX700 Quick Start Guide pages 85-93,:Nozzle Check
Pattern,Print Head Cleaning,Print Head Deep Cleaning and Aligning The Print Head
Mar 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MX700. I tried to send a fax then
Try removing the ink and printhead, turn printer off and then on. If printer asks you for the printhead, then ink, then you may have just gotten a working printer again. I hope this works.
Jun 05, 2017 | Canon PIXMA MX700 All-In-One InkJet...
White lines across text on Canon MX700
It sounds very much like a failed printhead or printhead driver; the circuit that controls which jet is addressed or left blank.
Feb 12, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
127 people viewed this question
old marine
old marine
